Question about Vulcan Heating & Cooling
I was given a vulcan powerhouse 100 ducted heater and am trying to work out if i can put a brivas mercury switch thermostat on it. Im unsure as to where to put the wiring for the thermostat. I have no manual for it. Can you help?
  • 86 Answers
SOURCE: vulcan cx90 ducted heater
240 volt wiring required.
Posted on Mar 17, 2008
SOURCE: I need instruction for a vulcan ducted gas heater
ineed to unlock my sim card said puk code and idk
Posted on Feb 11, 2010
sloooo44
  • 235 Answers
SOURCE: Is vulcan duct heater still in existence?
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
Posted on May 12, 2010
  • 16 Answers
SOURCE: problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Posted on Jun 11, 2010
SOURCE: Brivas ducted heating not firing up. Gas supply ok
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Posted on Jul 16, 2010
How do you convert a remote thermostat to a directly wired digital thermostat to a vulcan powerhouse 100 central heater unit
First, you need to know how many millivolts the Thermopile (aka Pilot Generator) on the the furnace's pilot assembly millvolt terminal. Then you find a wired digital thermostat, that meets the same millivoltage that the Thermopile Generates or has a lower requirement. You have to run millivolt wiring from the furnace's pilot assembly millivolt terminal block (the wiring should be connect to the TH & the TPH terminals, to where you want to place the digital wall thermostat. In most cases, it can not be more that 15' away from the furnace. In other words, no more than 15' of wiring can be involved.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Heating & Cooling
Problem with Vulcan Powerhouse 145 cental heating unit.
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
Is vulcan duct heater still in existence? My problem is the thermostat control for the room temp has gone out of control - from 22 -35 0C. This has affected the heater cut off efficiency.
May 12, 2010 | Vulcan AUW230A Heater
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Thanks,
J
Apr 30, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Chasing a vulcan power house 100 user manual
Follow this link. There is PDF with vulcan powerhouse instructions on there. Hope this helps http://www.bonaire.com.au/support/documentation/owner/default.aspx
Jul 16, 2009 | Heating & Cooling
Why does this model ''whp12a02oba000c'' read low batterie? If there is a batterie where is it located?
Vulcan Powerhouse or similar???
Batteries (3xAA) are in the thermostat on the wall. Undo 2 screws at bottom of control and pull open from the bottom.
Jul 13, 2009 | Heating & Cooling
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Heating & Cooling
Vulcan cx90 ducted heater
Mar 06, 2008 | Heating & Cooling
Heating & Cooling Logo
249 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Oloyede Monsuru
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
