I have a Whirlpool washer and the motor coupling needs to be changed. I purchased the part and it appears that all I need to do is to remove the motor, pull out the old coupling,replace it and put back the motor. An article on the web has me removing the console, the water pump and a bunch of other parts just to get to the coupling. So, I am confused. Please advise. thank you, Rob
  • 2 more comments
  • rthisoldhous Jun 28, 2009
    My originaql question was not anbswered - why do i need to go thru all of the prior technicians method when I can see from the bottom of the washer the motor and the coupling that needs to be replaced. It just seems I would be taking the entire machine apart if I followed the technicians advice.
    Rob
    Rob
    Rob
    If your solution was that easy, why did the first technician almost have me take apart the whole washer?
    Rob
    President:
  • 744 Answers
Ok, if all you are doing is replacing the coupling here is how you do it....Pull machine forward....Tilt it back so you can access the bottom...make sure you wedge something underneath so machine does not fall on top of you while working on it. Now pull 2 clips off pump, pull pump off mount and push aside..Remove 2 screws from motor clips...remove wire harness from motor, now remove two clips with a screwdriver holding motor in place...drop motor our onto the floor...replace coupling and rebuild the motor and pump in reverse order you took it off...make sure you reattach the wire harness onto the motor...thats about it...anything else is mumbo jumbo...have been replacing these for 20 years and this is easiest way and quickest. Hope this helps...good luck!
Posted on Jun 29, 2009
  • Mike Price
    Mike Price Jun 29, 2009
    Hi Rob, Just reading some of your previous comments, Other techs will tell you to pull the machine apart because that is have they learned in trade school...basically there is the right way to do it and the easy way to do it...the way i gave you to do it is the way i have found over 20 years of experiance the easyiest way to do it...hope all went well and you are up and running again.
  • 508 Answers
You can just remove motor and soak coupling in penetrating oil remove and replace!!!reinstall!!!Best of Luck to You!!!!
Posted on Jun 28, 2009
  • 3,230 Answers
First unplug the unit. the console has to be tilted you most remove two screw to do this one is on the far right the other is on the far left. note the new models under about six years old the screw are on the back of the console. after tilting the console you need to remove to large clips far left and right they're a goldish color use a regular screw driver to pry these out they release at the front of the clip use caution this is the hardest part of the job as a newbie. now unplug the quick disconnect on the cabinet locate under the console right hand side. now the cabinet is ready to be removed lift up and forward set cabinet out of your way. now locate the pump to hose going to it in the middle of the washer at bottom. remove the two clips no need to remove hose will make water mess pull pump forward and off push to the side out of your way. now two clips on the motor needs removed they're is two screws one on each clip they will be removed 1/4 or 5/16 then remove the clips the motor it will basicly fall off pull it out so you can see the other end of the motor that is where your coupling is located. remove it off the motor and the other side of the coupling off the transmission install new coupling reverse your steps your done
Good Luck!!
Thanks
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Oct 24, 2012 | Whirlpool LTE6234D Top Load Stacked...
The mptor works but the agitator does not.there is a white coupling between the motor and transmission that appears to be worn.are they replacable
Yes thats the most common failure on those type of washer's..the motor coupler will wear and break. The part number for that coupler is 285753A it could be purchased at your local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.copartselect.com
Sep 11, 2011 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool top load washer does not spin. Does
Hi, the likely problem here is a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
8fbd130.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Dec 26, 2009 | Whirlpool Washing Machines
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer stopped spinning 2 days ago. water drains fine.
hi. thanks for the question. the motor drive coupling is the part you need .It drives the transmission.about $25.00. you have to remove the cabinet .To do so .2 screws at the end of console, by the top .Remove them .Lift up console. 2 Brass clips remove them. disconnect wireing pull cabinet towards you .remove the pump disconnect power to motor. remove the motor . replace the coupling. thanks the appliance doc
Sep 28, 2008 | Whirlpool Washing Machines
WHIRLPOOL TOPLOAD WASHER LSR7233EZO
hithe part you need to replace is called a drive coupling which goes between the motor &transmission you have to remove the cabinet to get to this part if you tip the washer towards the wall and look between motor ant transmission to remove the cabinet 2 screws at the console where cabinet meet lift console 2 brass clips 1 each side spring clips screw driver in cavety and pry remove cabinet 2 clips on pump remoce 2 screws on motor remove 2 long metal clips on motor disconnect wiring from motor remove 2clips from remove motor replace coupling thanks the appliance dod
Sep 17, 2008 | Washing Machines
WHIRLPOOL TOP LOADER 3RLSQ8000
ck coupling between motor and gearcase ..probably broken or cracked ..remove 2 screws on back bottom of console lift console up remove lid switch plug remove clips each corner remove cabinet remove clips on pump remove 2 screws holding motor clips on remove motor clips remove motor and there it is
Aug 19, 2008 | Whirlpool LSQ8000 Top Load Washer
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Motor/Isolation Coupling Failure Repair
You should do fine with this part. While it is apart look for any leaks and make sure that the hoses are all connected before you reassemble the machine.
Feb 14, 2008 | Washing Machines
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
