Question about Pyle BZDBP212 Car Subwoofer
Amp power I have everything wierd up but there is no power into the amp, but there is a slot in my amp that needs a fuse so im not sure if that is it any suggestions
    Problem Solver:
  • 15 Answers
Hi there, what size output is the amp? it should have a fuse provided. the other reason might be the amp isnt correctly earthed. check all the settings against any instructions you have. if this doesnt work dont hesitate to email me on
Posted on Nov 14, 2007
..@briver916...Recheck all the fuses and relays in the 2 boxes under the hood and another one of fuses and relays panel inside the car, front of the driver seat, behind the pull out box next to the hood release handle..Under the hood check inside the one with 8" black square box;Check # 1 slot fuse, it is 60 amps for (+B ), check # 8 slot fuse for Engine control 20 amps, check # 15 slot Fuel pump 15 amps..And check another skinny black box lie next to that box, it has relay F, that is Engine control, check that also...And inside the car fuses panel; Check # 1 slot fuse 10 amps that for Ignition coil, # 8 slot Engine control 7.5 amps, # 12 slot Engine control 7.5 amps..After that recheck the battery post, that maybe needed re-tight..Don't force to tight too much, that will crack and broke the post and the plastic battery body...And check all the ignition wires and spark plugs that are tight or needed to replace..And check all the vacuum lines that are loose and leaks suctions or sometimes they are crack open by long ages..By the way check and recheck all those other fuses and relay for make sure they are good...Believe me that not hard to figure out those problems..You did everything rights so far..That one 100 amps fuse at the + battery post cable was connect to alternator for recharging your battery and give power to other items when car was running..Below that post, the middle cable was connect to the starter motor and the bottom cable was connect to that 8" black fuses and relays box under the hood...
Sep 20, 2011 | 2003 Mitsubishi Lancer
What size fuses do i need for the 3 slots and im blowing the power fuse its all hooked up right
  • A Metrik MAX-1404 Amp requires 3 20 Amp Maxi Blade Fuses yellow in color.
Regards, Tony
May 23, 2011 | Metrik Amplifiers MAX-1404 Car Audio...
Xbox wont turn on i just finished downloading halo wars and a few miniutes later it shut off
hey a :-)
is ur power brick 'green/orange/red light on ??
if it is firstly make sure its fully pushed into ur 360 ! (i sure u tried this already)
It could be RED' ?? but it dosnt really matter.....its still the same fix !
assuming you have some sort of power to the power brick (any colour)
un plug it (from the mains).......
im gonna guess you have been using some sort of USB connection (either a controller charger, wired controller or usb stick)(music ect ect)....either to the 2 front usb slots or the 1 at the back.......??
if this is the case un-plug EVERYTHING from all used usb slots........
now try powering up the 360 .......??
If it still dosnt power up (assuming you have some light on the power brick??) revert to plan 'B'.....
un-plug the power brick from the mains again.....& unplug 'ALL' connected leads from the 360 so you just have the 360 with nothing plugged in ! if you have a torch ect have a look inside all usb slots you have used (for charging ur controller ect even the back one if u have used it ??)
inside all used usb slots are little 'prongs' ...if in the process of plugging in & out chargers/wired controllers ect you accidently bend one of these prongs & it touches the sides of the casing surrounding the usb slot it shorts the board out & results in 'No power up' of the xbox ! its a simple problem to fix yet difficult to spot unless ur told about it !
usually un-plugging all usb used slots rectifys the problem but failing that check inside them for bent prongs !
I find a pair of tweezers or a tiny screwdriver does the job best :-)
plug power lead back in & try again
let me know how u get on ??
hope this helps ??
Feb 13, 2010 | Microsoft Xbox 360 Console
2002 F150 SuperCab Power Windows via 5A radio fuse. Wierd!
The location for the circuit breaker is in the fuse box under your hood number 601. Its a 30a CB.
Aug 09, 2009 | 2002 Ford F150 Regular Cab
Amp wont kick on
you have to instal the remote wire or it will not work. I'd put in the other fuse as well just in case you have the fuse in the wrong slot or it needs both fuses.
Nov 14, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Coustic 601se power on but bad sound
This is generally caused when there are blown output transistors but that generally causes the fuse to blow or causes the amp to go into protect mode.
If you connect a 15 amp fuse in series with the main power wire and it blows when remote voltage is applied, the amp is drawing excessive current. The problem could be either in the power supply or audio circuits.
Do NOT apply power without having the transistors clamped TIGHTLY to the heatsink. They can fail in seconds when there is a problem. The heatsink helps protect them.
The following page may be helpful when troubleshooting.
Amplifier Repair Primer
Let me know if you have any other questions.
Aug 23, 2008 | Coustic Car Audio 601SE Car Audio...
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Problems with the Operation circuit on Technics SU-A900 MKII aplifier.
Hi There Cushy,
The Amp needs Power.....and if the power switch is turned on and the light doesnt come on then there is no power....
Have a good look around the back of the amp and see if you can find a fuse please...
Its a small circular plastic item labelled "FUSE" with a screwdriver slot in it..
Turn the power off at the wall socket then unscrew this fuse holder, the glass / ceramic fuse will come out,,, replace it with one of the same physical size and of the same rating probably 1.5Amp.
Turn the amp back on and it should go if not then there is a major failure inside the case.....Needs a serice call Im afraid....
Cheers From YUBEUT
Nov 17, 2007 | Audio Players & Recorders
No sound
I would try it without the slot for the additional amp. However, there is a chance that it is fried. When its powering up I would check the voltages with a multimeter to make sure everything there is in order.
Jul 02, 2006 | Infinity 7540A Car Audio Amplifier
Pyle BZDBP212 Car Subwoofer Logo
42 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
