Question about Dell Dimension 3100 PC Desktop
Im looking for internal parts of computer monitor.
  • Dell Master
  • 32,281 Answers
What kind of monitor, a CRT or LCD type?
What kind of parts are you looking for?
The CRT type has dangerous voltages inside the unit and unless you know what you are doing, I would not suggest you go poking around inside a CRT monitor.
Posted on Jun 28, 2009
Hard desk
Posted on Mar 13, 2011
Personal computer how detect virus
Posted on Aug 26, 2009
Kinds of monitor
Posted on Jul 06, 2009
Volume control
name full model number, zillions made.
im clueless
are you using internal monitor speakers, are they connected right?
Sep 28, 2013 | AOC Monitor
Hi, i have an acer lCD monitor model x223w, the screen light flickers for a few seconds then the moniter shuts down. what can i do to fix it?
if no any power led indicator at the front panel after of shut down, the cause could be power supply failure. you will need to remove the back cover to gain access of the internal part of the monitor. look for a blown fuse or burnt parts at the power supply board. if you have an idea about electronic parts just replaced defective parts with the same rating and value. hope this can help good luck just let me know if you need further assistance.
Nov 08, 2012 | Acer 22" X223w LCD Monitor
Monitor wont turn on
Usually the capacitors are 1500uF/25V and 470uF/25V, but I suggest to use 35V capacitors. This will make your power supply to last forever. Also, you better open the monitor and see by yourself what kind are the capacitors. Mind the polarity or the capacitors will blow out with lot of smoke. You can buy them from local parts store like Conrad.com or online.
Apr 07, 2012 | Samsung Computers & Internet
I have an Acer X193W....looking into the blue light on the power button it seems "dark" at the middle of the power switch light.....is this a burnt out light or do I see an internal part that is...
You are right. You are seeing an internal part that is in the middle of the light.
Specifically, the light is an LED (light emitting diode) the part you are seeing is the stand on which the actually silicon chip is mounted.
Jun 22, 2011 | Acer X193W LCD Monitor
Power light on no picture
haukke, Monitor may have internal power supply failure due to some common parts failure. Use warranty if valid. Visit www.badcaps.net , www.lcdrepair.us , www.lcdparts.net , www.ccl-la.com/badcaps.htm You will also need to find video clips on YOUTUBE to see if DIY repair will work for you. Try "LCD monitor disassembly" or "LCD monitor repair" as search querey on YOUTUBE. After research finished, then let tech's here at fixya know what you will do by doing additional comment to this one. 12fixlouie
Apr 08, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Screen shows for 2 seconds, then black, power button still on
You could have an inverter problem or a faulty CCFL lamp/s.
For service, parts and DIY info I found LCD Parts helpful, use this link to get to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | HP f2105 21" LCD Monitor
All dead except for flashing amber light.
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Need help
engm_azazy,
Viewsonic has a lost of parts that they can give you. I would recommend to call their parts team to help out.
1-877-BIRDS4U
piolo2,
Im sorry man but your monitor is shot. If it works on another computer then your video card is shot.
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
Trying to install my proview monitor
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 19, 2008 | Gateway FPD2275W LCD Monitor
Internal Monitor speakers
change you your speaker wire or check and make sure it is pluged into the back of the computer in the correct spot
Aug 30, 2007 | LG M1717S-SN Monitor
Dell Dimension 3100 PC Desktop Logo
1,167 people viewed this question
Alun Cox
