Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
    New Friend:
  • 92 Answers
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
We have a hampton bay ceiling fan model 54cvt. We - 9cca4aaa-86c1-4214-a3b9-47ed956c2b02.jpg
Posted on Aug 01, 2013
MrARCADIAN
  • 284 Answers
SOURCE: Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Posted on Aug 16, 2008
jyackle5
  • 8197 Answers
SOURCE: Need a fan blade attachment
You can buy the blade attachments at home depot
Posted on Jan 22, 2009
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
SOURCE: Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Posted on Oct 01, 2009
Change upper light bulbs on hampton bay model 560-084
Please check the manual. If you dont have a manual you can download a free copy from here
Hampton Bay Lighting Manuals
These manuals are courtesy of Hampton Bay
Dec 02, 2016 | Hampton Bay 24002 Ceiling Fan
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Light-Kits/Hampton-Bay/N-5yc1vZc5t3Zp4
Aug 14, 2016 | Hampton Bay Dryers
I am trying to change a light bulb in a hampton bay fan model uc7080t or thats what the remote says. I am also trying to figure out how to reverse the direction of the fan blades. Any help would be...
That sounds better, you first said the remote told you...
1. your remote will have a reverse button or a fwd/rev button
i dont know which remote you have
2. as far as the globe, if you dont see little screws holding in place
you have the twist style, you will rotate the globe. their is also a chance if it made of soft plastic, it will pop out
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Hampton Bay 52 In. Huntington Ceiling Fan
I HAVE A HAMPTON BAY CEILING FAN. MODEL FAN-2R
On the body of the fan motor is a small sliding switch(up and down), if you cannot reach it you can use a broomstick to carefully change it's position.
Sep 07, 2009 | Hampton Bay 24002 Ceiling Fan
Light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Mar 27, 2009 | Hampton Bay 24002 Ceiling Fan
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Hampton bay model 55295 fan works, light doesn't
Did someone give you advice on this? My fan is doing the same thing. Fan works fine, but the light does not. Looks like the electricity is not making it down to the ballast - trying to figure out how I can repair it.
May 27, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
1,813 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
