Question about HP Computers & Internet
Hi my hp laptop is wireless and my internet is not working because it can't renew my ip adress and contact the dchp server and advice?
  • 788 Answers
If you can connect with a hard wire connection, your problem is in the network configuration.
I would turn off the wireless and try the hardwire 1st. Their you can jump to a DOS Prompt and type IPCONFIG /?. This will give you the layout for ipconfig. If you type ipconfig /all, ipconfig /reset, or just ipconfig, you will be able to get around your settings.
Also if you are having problems with the router or modem, you should unplug it and let it sit for 15-30 seconds and plug it back. This will reset the device and make it easier to reset with software.
After all is done and your lan configuration is correct and working, unplug it and switch the wireless on. Double click on the wireless icon, bottom right and if you are in range of a network, you should be able to go from their.
One last thing, if all else fails, you can double click on the network icon, bottom right and click the support tab and then repair.
Again, doing this will work much better if only one network is active. After wards, you can switch on the other and use both if necessary.
Hope this helps, Try it. it may work !!!
John Ray
john@johnrraycomputer.com
Posted on Jun 28, 2009
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
My laptop connects to a wireless network but it always tells me that I have no internet access, what is the problem?
1. turn off your wireless adapter, then turn it on again.
2. unplug your wireless router for 10 sec. then turn it on again
3. if non works, try renewing your IP adress in command prompt type "ipconfig/release" then "ipconfig/renew
those should work hopefully
May 16, 2011 | ASUS Computers & Internet
Desktop prints fine but laptop will not print going through dlink 1260 print server either wired or wireless. I should say I have a linksys router that my desktop is hardwired to, but the Dlink server is...
as no one has answered this I will give it a go .
Check or download the latest printer driver for whatever operating system the laptop is running.
Could be a dhcp server clash from the wi fi print server and the link sys router . Check there are two DCHP servers and if there are deactivate on and use the other .
check the ip addresses in use on the laptop and on the desktop and the printer. make sure subnet mask are all the same but ip addresses are unique but within the network range. eg 198.168.0.2 - 198.168.0.254 and subnet mask 255.255.255.0
or 10.0.0.2 - 10.0.0.254
check the ip address for print server is different to the ip address for the router and make sure DCHP range does not clash with router assigned ip addresses .
Dec 26, 2017 | Toshiba Satellite A205-S5831 Notebook
No internet connection,
hi
if you have already configure your router and it was working following thing could have happen
1) you have lost connection to internet ...go to your router setup page under status make sure you have connection
2) once you have your router connected re-boot your laptop or pc or renew your wirless connection
good luck
Jun 12, 2009 | Linksys WRT54G2 Wireless Router
Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Jan 15, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Shared internet connection help!!!
are you using window xp for both pc?
Aug 25, 2008 | Computers & Internet
Will sync but online LED won't work
4 Select the connection type from the Connect Type drop-down menu. ? Always Connected means that Internet connection to your ISP is always on. ? Auto - Triggered by Traffic means your Router will automatically connect to your ISP every time a PC needs to access the Internet. ? Manual - Start in Disconnected means that after re-booting the Router, the Internet connection will need to be re-established manually by the user. ? Manual - Start in Connected means that after re-booting the Router, it will automatically establish a connection to your ISP.
(from http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02582095-1.pdf )
this sounds like Manual - Start in connected mode will get the ip address and dns settings automatically from the ISP
using adsl on phone line then use pppoe for the protocol
DCHP server has to be set up also and on
The DCHP server ip address range is 192.168.1.20 to 192.168.1.254 with subnet mask 255.255.255.0 and default gateway is 192.168.1.1
pppoe protocol allows the ADSL to connect many computers on the one isp global ip address allocated to your line via using different port numbers to translate the computers internal ip address on the dhcp server through the router.
Jul 01, 2017 | 3Com OfficeConnect Router
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
