Question about Vivitar ViviCam 3710 Digital Camera
My Camera I Have a ViviCam 3785 digital camera. It worked Great untill it said my memory was full(i didnt use a memory card and still dont have one) but it says my memory is full but there is no pictures on my camera. I Can't take any more pictures because It says my memory is full. But theres not pics on there?? Can ne one help me?
  • 99 Answers
Did you possibly shoot video by mistake? Please check the video setting and see if you have a video that has filled the memory so its is full. If you have you can delete it, otherwise, run the format command from the Cameras menu and that will place the memory back to square one and you should be good to go. / Please let me know if that works! Thanks //D
Posted on Apr 25, 2008
make sure the lock on the side of the memory card is in the unlock position. sometimes they will lock when inserted into camera. good luck.
Dec 07, 2010 | Vivitar ViviCam 3785 Digital Camera
Added new memory card. Camera says that the memory card is full..How do I correct this?
Assuming it is not actually full, this might mean the card is incompatible with the camera (too high a capacity) or it might mean it needs formatting. Usually a camera will say if it needs formatting, so I would check the camera specs to see whether you have a memory size it can handle. SDHC cards are not backwards compatible with SD cards.
Oct 22, 2010 | Vivitar ViviCam 3785 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
1. Press the button to turn on your ViviCam 3785.
2. Press the MODE button twice to enter Playback mode. Then press
the button to enter the Playback menu.
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
5. If you want to format your SD memory card or the internal memory choose
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
 To cancel the action, select [Cancel] instead.
 [No Image] pops up after the SD memory card or internal memory
has been formatted.
If you need a manual for your camera you can download a free PDF at
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Can i use a 2 gig sd card in the vivicam 3785
Manual says that camera only supports up to 512MB. Just tried it with a 2GB card now--gives a "Card Full" error.
Oct 12, 2009 | Vivitar ViviCam 3785 Digital Camera
Any suggestions on what SD card to use with this camera?
I put in a san disk ultra II 1.0 gb and it works fine. I don't know if it means anthing but my card is the breakable kind. You can break it down to go in a computer. I could not turn my camera off, I could not load pictures, it would tell me that my card is full and i was ready to throw it across the room. It works great now!!!
Dec 30, 2008 | Vivitar ViviCam 3785 Digital Camera
When i try to view my pictures a memory error comes up.
most likely the memory you are using is either corrupted or not damaged, try using a diferent one similar to the SD card you are using...
Dec 15, 2008 | Vivitar ViviCam 3785 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
I can't find the memory card slot on th 3785 camera. where is it.
I checked out the user manual and it looks like the SD memory card slot is located right next to the battery. Just open the battery compartment and look near the hinge and you will see a place to put an SD memory card. Here is a link to a pdf version of the manual which is nice to have even if you have the printed version:
Click HERE.
Take Care,
Aug 19, 2008 | Vivitar ViviCam 3785 Digital Camera
Vivitar vivicam 3785 new memory card
Might be that the card is too large/small for camera to recognize, or it is a newer type of memory. Look up the specs for camera and compare to stats of memory card.
Nov 13, 2017 | Vivitar ViviCam 3785 Digital Camera
Recording of video on camera makes camera freeze
If the camera works when one of the cards is used then the camera works. It just doesn't work with the other card - Due to a compatibility problem or a busted card. Are the cards both from the same manufacturer?
Apr 20, 2006 | Vivitar ViviCam 3785 Digital Camera
Vivitar ViviCam 3710 Digital Camera Logo
43 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
