Question about Baumatic B151 Electric Single Oven
Inner glass door on oven shattered
Our second inner glass door has shattered - again within minutes on turning oven on, first door replaced under warranty. Oven not used a lot, not overheating, door only cleaned as in manual, immaculate condition, no chips on knocks etc - is this a fault in the glass of this model, or is it being fitted wrongly so the glass is in a stressed state before switching on heat. Have never had problems with glass oven doors before.
MNTECH
  • 1543 Answers
SOURCE: Broken Inner Glass Door
The inner glass panel is a part number 316117500
Anyone who services Frigidaire, and some others can get one for you. Here in the midwest I get lots of my parts from C.E. Sundberg Co., based in Chicago. They have this part on hand in Chicago, St. Louis Park (Minneapolis), Omaha, and Milwaukee, and will ship. Cost should be under $100. Even more info than you asked for, sounds like a FixYa, yes?
Posted on Nov 28, 2008
barkencoa
  • 3463 Answers
SOURCE: Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
SOURCE: Baumatic B147SS oven was giving no heat, fan and
might sound silly but have you set the clock. as the oven wont work otherwise.
Posted on Dec 22, 2009
barkencoa
  • 3463 Answers
SOURCE: The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Posted on Jan 24, 2010
SOURCE: inner glass on bosch HBC84k550b microwave
Strangely enough I had exactly the same problem but today managed to fit the new inner glass and door panels without any problems, here is how.
YOU NEED 2 PEOPLE FOR THIS STEP. Open the door, at the top are 2 large plastics flat head screws, undo these making sure your helper is holding the door securely or itll fall on the floor, te door will unhook once the screws are fully undone
Once off you can close the microwave back up.
Now there are two screws, one in each top corner holding a funny looking plastic wing shape that slides into the inner door. They have a star screw head. Undo both of these and remove the plastic wings. When you remove these the panel underneath will try to fall off so be prepared to catch it, along with the plastic screws undone in step 1. This now unhooks like the main door did.
From here you'll be able to see the back of the inner glass. This is held in by a mesh at the back and about 15 screws, star headed again. you can simply remove all of these, that will release the front panel over the inner glass, again, you might want someone to hold the door open so the panel does not drop when you remove the last screws.
Thats it as far as taking the microwave apart. put your new glass in, remembering to make sure the rubber seal is put back between the glass and inner door.
Simply reverse the process.
It took me approximately 1 hour and I am by no means a DIY person.
Good Luck
Mike
Posted on Feb 11, 2010
Korting oven
contact the dealer/ distributor in your area or contact the maker direct. You may be up for a new door as sometimes the glass is glued into the door for sealing purposes.
May 18, 2013 | Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Kuppersbusch microwave door glass replacement
Did you resolve your problem as my inner door just shattered and will need replacing? Do you know why yours broke?
Jan 09, 2012 | Ovens
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
Jan 24, 2010 | Zanussi Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Just the glass piece. Look up parts on any parts site or let the supply house do it for you. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
Baumatic B151 Electric Single Oven Logo
274 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
