Canon imageRUNNER 400S Copier
Problem for Canon imageRUNNER 400S Copier
Toner not set insert toner message
By map1954 on Nov 06, 2007
I have a canon imageclass mf 4150 toner ran out and we installed new toner. now it will not work keep getting error message, "toner not set insert toner" tried 2 new cartridges both get the same message
Appreciate any help available
Same Problem
Dec 05, 2009
-   Worked for me to reisert paper, too.
thanks-   sherwoodne
Apr 02, 2009
-   Same problem, paper solution worked like a charm! Thanks!! -   rickey657
Feb 11, 2009
-   Paper trick worked for us too, thank you very much!
Sprint-   Guest
Jan 06, 2009
-   toner is not set -   sschwartz84
Dec 15, 2008
-   I have done everything listed above. It still has the error mesage of " toner is not set- Insert the toner- What do I do? -   Guest
Best Solution
posted on Nov 09, 2008
Very Helpful)
Guest
Rank: Apprentice  Office Equipment  Expert
Rating: 0%, 0 votes
Yes that paper trick also worked for me. Thanks for putting it up!
Solution #2
posted on Sep 29, 2008
Very Helpful)
Guest
Rating: 0%, 0 votes
Same problem ... it was the paper tray ! Take out all the paper, re-insert ... and all fixed.
Solution #3
posted on May 29, 2008
Very Helpful)
Guest
Rating: 0%, 0 votes
I tried removing the paper followed by a power cycle and it worked. I don't get it but I'm not complaining.
Thanks all!
Solution #4
posted on May 24, 2008
Very Helpful)
Guest
Rating: 0%, 0 votes
Solution #5
posted on Apr 24, 2008
Very Helpful)
Guest
Rating: 0%, 0 votes
I had the same problem with a Canon MF4150 and the paper fix worked. Thanks for taking the time to post what you had discovered.
I pulled the paper, turned it off, took the toner cartridge out and set it back in, and all worked fine.
Solution #6
posted on Nov 07, 2007
Very Helpful)
jules_09
Rank: Master
Rating: 77%, 64 votes
hi im jules_09.canon use a magnetic type of toner are you sure the toner you have is right?if you replace the toner already just let it warm up for a while then let the copier free run.sometimes it takes time for the toner to mix in the d v unit.
Comments:
Nov 07, 2007
- if that doesnt work go to program then use toner force supply thats what i do if the toner error is on if that still does not work replace the d v unit there its deffective already.all dv unit especially non magnetic has a copy limit if you reach that limit you will replace it otherwise the toner will not work that goes with magnetic type of d v unit
Was this helpful?
Yes
No
Solution #7
posted on Mar 19, 2008
Very Helpful)
Atkintap
Rank: Apprentice
Rating: 99%, 22 votes
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #8
posted on Oct 02, 2008
Very Helpful)
abhuyada
Rank: Apprentice
Rating: 99%, 5 votes
toner catridges error show in display but be toner is correct.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #9
posted on May 18, 2009
Very Helpful)
HimFirst
Rank: Apprentice
Rating: 100%, 1 votes
I pulled out the paper, turned the machine off, reinserted the paper and restarted the machine. The toner message went away.
Was this helpful?
Yes
No
Solution #10
posted on Dec 21, 2009
Not Rated)
linksan
Rank: Apprentice
Rating: 0%, 0 votes
Weird, but great solution. Just removed the paper from the tray, placed it back and it worked. :D
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 400S Copier
Questions and Unsolved Problems for Canon imageRUNNER 400S Copier
Do you recommend Canon imageRUNNER 400S Copier?
Answer
Answer
where is the copy copy counter located on the IR400S?
Answer
canon ir 400 xerox machine error code e200
Answer
When I try to copy, only blank sheets of paper come out. What would be a solution to look for?
Answer
I am trying to mount the side unit to my copier. help?
Answer
minolta 7145 - in ftp - error is -network connection not aviable n-87
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 20, 2008
It worked!!!! Thanks
Comment by Guest, posted on Mar 31, 2008
I had the same problem with a Canon Imageclass MF4150 and the paper fix worked!! THANKS !!!!
Describe your Copiers problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , NY
(805) 813-1755
Full line Canon, Konica/Minolta, Panasonic and HP...
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
