Question about Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer that has been blowing the breaker, and is not heating up to dry clothes
  • 232 Answers
How long is it run when breaker is blown? element could be blown and shorting to the cabnet. motor could be full of lint
Posted on Jun 28, 2009
  • bill williams
    bill williams Jun 28, 2009
    element could be broken and shorting to housing unplug it dont keep trying it you could start a fire
Clothes aren't drying
check circuit breaker first heat and motor on different circuit,one side may be tripped, then continuity on element,then limit switches
Feb 13, 2013 | Whirlpool Dryers
I have a ler4634eqo and it runs but it stopped heating up and drying the clothes. It still blows air just cold air.
check circuit breaker heat is on seperate circuit may run with one circuit then check continuity on element,then limit switches, then timer
Feb 11, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer won't dry clotes Model# LER4634PQ1
Dear Sir:
Please see this possibles causes:
Power from the house
test for blown fuse or c. breaker tripped, change or reset.
Heating element
test for burn or open heating element see the video
Thermal fuse
test for open fuse, see the video
Wiring
test for burn or break wires. test for continuity.
God bless you
May 23, 2012 | Whirlpool LER4634J Electric Dryer
Are there fuses in the dryer? Not getting hot. Could it be the heating element?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Whirlpool WED5100SQ Front-Load Electric...
My dryer does not heat. how can i fix it?
Hi
Electric Dryer---
Hope this helps...
Daniel
Sep 15, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not start
Hi
Hope this helps...
Daniel
Sep 14, 2010 | Whirlpool GEW9200L Electric Dryer
Not heating up
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Post back if more assistance is required. Hope this helps...
Daniel
Sep 03, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer heating, but not drying
hi..you probably have a tripped electrical breaker.
check your breaker box first and reset any tripped
breakers.If that doesn't work,you may have to replace
the heating element.
check it out..
thank u..
kindly rate my response..
May 17, 2009 | Whirlpool Dryers
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
