Question about HP Compaq Presario V2000 Notebook
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
    Scholar:
  • 103 Answers
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Posted on Feb 03, 2015
SOURCE:
  • 11 Answers
SOURCE: compac presario v2000
ther must b a problem wit the ram...try replacin it...don 4get 2 vote
Posted on Mar 24, 2008
  • 1257 Answers
SOURCE: Presario V2000 will not boot
When your computer starts press f10 to enter the bios ,there you will find the option to reset its setting to default.....
Was this solution helpful .Show your appreciation by rating it.
Posted on May 30, 2008
SOURCE: Won't boot
i am unable to install operating system( WINDOWS XP)
Posted on Oct 30, 2008
dtillis
  • 10 Answers
SOURCE: My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Posted on Nov 12, 2009
Testimonial: "This solution seems to be common. Unfortunately it didn't fix the problem. Thanks for your help though."
SOURCE: Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Posted on Jan 19, 2010
I get nine beeps when I try to turn on my HP Compaq desktop computer.
you have a corrupted OS system file, if you have the original Windows CD you can insert and boot with it follow instructions and will need to re install the OS, by performing a repair. BE AWARE that you could delete all you programs and personal files, if you select the wrong procedure.
Sep 01, 2013 | HP Compaq Presario V2000 Notebook
Installed more memory into Compaq V2000
The new ram you have installed, is it the same speed/type as what is already in the system?
Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
May 30, 2008 | HP Compaq Presario V2000 Notebook
Compac presario v2000
try reseating the RAM,if that doesn't work replace the RAM
2 Beeps = bad RAM
Mar 24, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 fails to boot up
3 beeps is the Beep code for "Base 64KB RAM Failure". Lets hope that you are lucky and the problem is your memory. If you have two memory sticks in the computer, then try to take one of them out. Try different combinations such as swapping between the memory slots that are available. If you still getting the same error code, then your motherboard is shot.
Aug 16, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
