Question about ViewSonic VA1703wb Monitor
Monitor won't display resolution properly after Windows Update
I foolishly downloaded and installed Microsoft's Driver for the VA1703wb via Windows Update. After a restart, it won't display the optimum resolution (1440x900). I've tried uninstalling and reinstalling both the Video driver (Intel 945 chipset driver) and the Viewsonic monitor driver without success. Has anyone run into this problem before?
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Posted on Dec 08, 2007
Yup i too..
This is the worst quality monitor as I found in my life
I used to work in office
This worst sonic monitor has few more problems
when u decrese contrast brightness sudenly jumps to highest value in this montor
S'illy when u increse brightness contrast goes to zero
I realised to throw it into dust bin.
Posted on Nov 18, 2007
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
Attention autoconfig please wait -- this message keeps popping up in the monitor continuously. it also adjusts the contrast anf brightness some times automatically. please help
Sounds like the "auto config " is built in to your monitor. It selects screen sizing based on the resolution, sync timing, refresh rate, etc... that your video card is adjusting on the computer.
I would suggest you to try changing the resolution in Windows and see if still receive the alert.
For more information on Screen resolution and display on monitor, check the below Microsoft Help & How-To Articles:
Change screen resolution :-
2: Getting the best display on your monitor :-
3: Troubleshoot monitor and video card problems :-
If it is doing it often and you are not changing screen resolution I would say the monitor itself might have issues. It's possible your display driver may be corrupted. I would suggest you to download and install the latest drivers for the Monitor from the manufacturer's website.
For more information on Updating a Driver and fixing driver problems, check the below Microsoft Help & How-To Articles:
1: Update a driver for hardware that isn't working properly
2: Tips for fixing common driver problems
Check the plug and cable, look for bent pins or pins pushed in.
Are you using one of those DVI/VGA adapters? If your monitor has dual inputs (DVI & VGA) have you tried using the other input?
Anyway you could check if the issue exists when the monitor is connected to another PC? Or maybe try another monitor on your PC?
Mar 12, 2011 | Computers & Internet
My viewsonic monitor VA1703wb image doesn't fill the screen
There are a couple of reasons for this problem.
1. The screen resolution was set too low. Try 1024 X 768 or higher.
2. If you cannot change the screen resolution then the video driver was not installed or the wrong video driver was installed.
Dec 04, 2009 | ViewSonic VA1703wb Monitor
I have a Compaq Presario 5420 computer and bought
You'll have to update your drivers for your video card by going to the Mfg. website and seeing if they have any later drivers than you're currently using. In my case, the 1440x900 monitor was recognized when I downloaded later updates, though upon initial installation it wasn't recognized. My card is an ATI from about 6 years ago.
First, we'll try setting the correct screen resolution. Go to an area of your desktop that has nothing on it and right-click with your mouse. Select the "settings" tab. See if your monitor is described properly in the drop-down box. If not, you may have to install drivers for it to get the proper resolution. Take a look at the slider and see if you can slide it to the proper native resolution for your monitor.
You can always try uninstalling the current driver. Go to control panel | system, click on the hardware tab, then click on the device manager button, expand "Display adapters" then delete your default display device. The best then then is to reboot Windows and let it find your display adapter. Possible that it will boot into the proper resolution, but if not, follow the above directions again, but this time don't delete the driver, instead right-click and select, "update driver." Let's see if that works for you.
Nov 28, 2009 | Compaq Presario 5000 PC Desktop
16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Nov 08, 2009 | Dell Computers & Internet
My viewsonic VA1701wb monitor having streching problem for images
The native resolution for that LCD is 1440x900. If you do not see that resolution in your display properties you can try to update the video driver. If it is still not displayed as an option you may need a newer graphics card. Many newer low end card support this widescreen resolution, so if you need to replace the card you will not need to spend a lot of money.
Mar 18, 2009 | ViewSonic VA1703wb Monitor
check out for the latest update of display driver .
also refer to user manuals of your monitor/display adaptor/ motherboard { may be a compatablty issue with the os}
and make sure that your pc is free of viruses
Mar 06, 2008 | ViewSonic VA1703wb Monitor
ViewSonic VA1703wb Monitor Logo
1,474 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
