No ac its not turning on? - Heating & Cooling
  • 156 Answers
Is this in a car. If so, first, check the fuse wherever the fuses are.
Posted on Jun 28, 2009
Nissan Ac problems
vent flap shutting off?
Jan 14, 2018 | Cars & Trucks
Hi my 2009 mondeo 20ltr titanium fan will not turn of. Start car without ac on fan comes on at full speed for a few seconds then goes of I turn ac on that comes on so does fan back to full speed not slow...
The fan is connected to the ac circuit to move air through the condensor in front of the radiator when the ac is turned on . This is to stop high head pressures in the ac and prevent damage to the compressor. There may be a problem with a coolant sensor that is turning the fan on otherwise so run fault codes and see if anything comes up
Dec 08, 2013 | Cars & Trucks
2005 ford focus zx4 ac compresser making noise when ac is turned on
Yes, it could be the ac clutch or the compressor itself.
Jul 08, 2012 | 2005 Ford Focus
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
New sound heard when AC turned n AC on. Metalic
compressor problem ,is the most likely cause ask a local mechanic to have a look
May 30, 2010 | 2007 Nissan Murano SE
1999 Alero: where is the a/c control tempature :problem is wh...
WELL TURN ON AC MAX COLD HIGH TO SEE IF COOLANT FANS TURN ON.IF NOT YOUR REFRIGERANT SO LOW THAT THE AC REFRIGERANT PRESSURE SENSOR WONT CLOSE CIRCUIT TO TURN ON COOLING FANS.MEANING YOU NEED HAVE AC CHECKED AND CHARGED.ALSO CHECK COMPRESSOR FOR POWER IF NOT YOU HAVE BLOWED FUSE OR BAD RELAY.IF FUSE AND RELAY GOOD YOUR AC COMPRESSOR CLUTCH COIL OPEN OR THE AC CONTROL SWITCH IS BAD.IF COMPRESSOR IS RUNNING WHEN YOU TURN ON AC YOUR AIR TEMPERATURE ACTUATOR NOT WORKING.
May 17, 2010 | 1999 Oldsmobile Alero
Serpentine belt slides over AC pulley when AC is off
The ac pump has a clutch coil,it is activated with the ac button,and then the middle of the pulley will turn this is the clutch,it only turns with the ac on,then when it is turned off,the pulley just turns not the whole clutch,so this is normal.
Apr 25, 2010 | 2002 Saturn L-Series
When i turn on ac it works on max ac not on ac
You have a blend door actuator motor that is not working,they are hard to get to,the dash has to be removed,and pulled back toward the seats to access the actuator motor.
Jan 21, 2010 | 1998 Ford Ranger SuperCab
How do turn my ac on?
you should move the switch to the "cool" mode and turn the thermostat to a lower setting, leave the fan in the auto position,verify that the breakers are on to your ac unit and that the wiring is correct for the operation of the ac
Jul 10, 2009 | Heating & Cooling
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
