Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
What is the fault F:16 on my Bosch Maxx Lifestyle front loader machine ?
SOURCE: New Bosch Front loader washer Maxx Classic WAE18060AU
if machine new have transit bolts been removed from rear of drum it amazes me how many of these get left in after delivery machine will go crazy if these left in drum should move backwards and forwards easily when door opened and drum pushes if solid remove bolts.
Posted on Jan 18, 2008
  • 1294 Answers
SOURCE: Bosch Maxx Instruction Manual
Click on washing machines above, then yr model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site
Posted on Jan 22, 2008
  • 6 Answers
SOURCE: Smellly Bosch Max 1000 front loader washing machine
(Posted this already, but found an AU site that sells Norwex detergent - a great product!)
We've had our Fridgidaire front load washer for 6 years now, and untilabout 2 months ago, it smelled absolutely horrible. I tried the thingsI was told to do....hot water/bleach cycle, wiping the slime from therubber seal, and leaving the door open....it didn't work.
Iwas told about Norwex laundry detergent - Norwex is a company whichproduces green cleaning products - the detergent is a quicklybiodegradable, highly concentrated powder, and all I need is 1/4 - 1/2a teaspoon per load. After about one week of using the Norwex detergentI noticed that the smell was completely gone and hasn't returned! Also,the gross slime that used to collect in the rubber seal is no longer aproblem. I've been so wonderfully amazed!
I don't know why thisdetergent fixes the smell problem, but I've talked with others who havehad the same great results with it - their smell issue was solved.Perhaps it's because it contains no animal fat products?
Anotherbenefit of the Norwex detergent is how economical it is - it comes in a2kg bag for about $25, and in a front load machine you will get approx.800 loads from it using the above mentioned quantity/load! It's reallyan amazing product! You can buy it online - www.norwexnaturallyclean.com.au (an Australian site) is a great site to buy from. Good luck with the smell!
Posted on Apr 18, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
How do you get the door seal clean or can you buy a new seal and how do you fit the new one on a bosch maxx lifestyle front loader washing machine regards andrew
The seal is called a boot. It is clamped to the outside of the drum with a large clamp and fits snugly around the outer housing.
Try using a lemon. Cut a lemon in half and rub it all the way around the boot, getting into the creases. Run a rinse cycle when clean.
Jan 28, 2017 | Washing Machines
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I cant even find the filter.
You don't. Washing machines don't have a handy accessible filter...
Check the owner's manual that came with the machine.
Feb 16, 2015 | Bosch Washing Machines
Replacing the door seal of a bosch maxx 1000
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Aug 26, 2010 | Bosch Washing Machines
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
391 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
