Question about Motorola Radio Communications
Dangers of a Motorola being left on when charging in a multilpe
Dangers of a Motorola radio being left on when charging in a multiple charging station?
  • brantwillett Jun 29, 2009
    Thanx Guru,
    I have always been taught not to have a 2way on when charging but was not certain why.
  • Motorola Master
  • 1,654 Answers
Don't know if you'd call it dangerous, but wisedom would be not to leave a radio turned on while on the charger. 1) Shortened battery life due to short charging. The battery will never be fully charged due to powering the radio. 2) Inadvertently pressing the PTT button while the radio on the charger can/will burn out components in the radio including the PA (final amp) which is a costly repair.
Instead of leaving the radio turned on while on the charger, buy a second battery to keep on the charger. Then you only need to swap batteries. Your radio would be able to remain on, and never be on the charger.
Posted on Jun 28, 2009
  • eradiostore
    eradiostore Jun 29, 2009
    You're welcome.
I have a Motorola 2070d can I use a usb cable to charge
drains too much power, it is better if you use wall charger with usb outlet
Feb 09, 2015 | Motorola Radio Communications
How do I get my motorola CP200 radio to stop making an annoying beep every time I transmit
Lincoln-
Motorola Solutions can help you with your radio. You can find their support available at Get Support .
Mark
Motorola Mobility Support
Jan 31, 2015 | Motorola CP200 Two Way Radio
Motorola batt charger
The charging unit may have monitoring circuit on each slots to switch the charging current to trickly charge to prevent over charging the battery.
Apr 19, 2012 | Motorola T8500 Two Way Radio
What is the range on a cruise ship
Typically most handheld radios have a range of 2 miles line-of-sight. However, obstacles between the two radios can significantly reduce range. On a cruise ship you may not be able to talk through multiple floors. To increase your range be certain to have fully charged or fresh batteries, and also hold the antenna upright, perpendicular to the earth.
Jan 29, 2012 | Motorola Talkabout SX700 2-Way Radio
Will the walkie talkie charge while turned on and left in the cradle? These are brand new models.
Not efficiently. It would take 3-4 times as long to get a full charge, as the energy is depleting nearly as fast as it is charging. The good news is most FRS radios will go up to 18 hours on a charge. Think of the charger as the radio's bed. When you go to bed, put the radio to bed too.
Best regards.
Jan 26, 2010 | Motorola Walkie Talkie 2-Way Radio
Motorola FV200R Talkabout dosent turn on
Yes, it is likely you need new battery packs. The Li-Ion batteries have a 12-18 month life expectancy. They will sometimes go longer if the radios are charged and depleted at least once a month. This style battery should be available from your local Motorola dealer on online at Motorola. http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601560
Sep 29, 2009 | Motorola TalkAbout FV200R (14 Channels)...
Motorola mts 2000 won't turn on
It is doubtful you ruined your battery, as they are designed to be left charging for periodic long periods, such as a full weekend, when a business is not open.
If you battery previously worked before charging it, I would suggest checking the connection to the radio, and the battery contacts on both the radio and the battery. It is possible you have flattened one of the contacts or some other contact problem.
If the battery did not recently work, it is possible it simply needs replaced.
Lastly, you might want to verify your charger is working. It is possible the battery did not get charged, and is completely dead. This is the least likely scenerio, as it is rare a battery is stone dead, unless it is no good.
Try a battery from a known good radio on the effected radio and make certain the radio is functional. If so, check the contacts, if okay, replace the bad battery.
Best regards.
Jan 12, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola talkabout t 6530
I just spoke with Motorola and they advised output for that particular charging base is 9 Volts 200 Ma output hope this helps, good luck!:)
Nov 11, 2007 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
205 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
