Question about Philips Zenia Voice Cordless Phone
Batteries OK, but not charging
I have a similar problem. Have changed the batteries and still - the handset is not charging properly. Actually it charges "a little bit", enough for just a couple of minutes operation.
I also tried to put in fully loaded AA batteries and it is still the same problem - the handset lives for just a couple of minutes...
Thought about opening the handset myself, but need some guidance on where to look.
    Problem Solver:
  • 6 Answers
WHICH MODEL?
Posted on Jun 28, 2009
New cordless phone showing out of range
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Dec 12, 2014 | Lands Phones
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
Handset 2 which is doc upstairs goes dead as soon as you want to use it
It's time for a replacement battery. Cordless telephone batteries can be purchased at most places that sell cordless telephones, or battery stores such as batteries plus.
A test for this is that you can swap the batteries with handset 1 and see if the problem follows the batteries.
Does it appear to be charging when on the cradle?
Attempt to charge Handset 2 on the charging cradle you have for Handset 1.
Good Luck,
Mark
Apr 02, 2011 | Panasonic Lands Phones
Not working
HOW OLD ARE YOUR PHONES?
maybe THE RE-CHARGEABLE BATTERIES NEED REPLACING (ACTUALLY DOES HAPPEN). COULD HAVE BEEN FAULTY BATCH INSTALLED.
CHECK CHARGER(S) IS CHARGING PROPERLY
Jul 12, 2009 | Uniden DECT 6.0 Cordless Telephone...
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
Philips Zenia Voice Cordless Phone Logo
467 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
