Question about Coleman Mach 15 Air Conditioner
Rv type,compressor stalls after runing about 5 minutes and will not restart until about 15 minutes later
  • 508 Answers
Remove top cover get degreaser at auto parts store use garden hose with spray nozzle spray off aluminum fins dont bend them spray degreaser throughly into fins let soak for an half hour then throughly rinse let dry then try those fins are dirty it will let let head pressure get to high then will shut off high pressure switch that a common problem used to work on refrigerated trailers number one problem problem the fan sucks in debris like vaccum clogs up fins and wont let freon cool!!!Good Luck to You!!!!
Posted on Jun 28, 2009
  • 156 Answers
That cover is not hard to remove. Remove it and check for obstacles first, while it is off :>) I had one do that as it had about a pound of dirt dober nest on the shaft. If that's not it, cut it on and when it stops, cut the power first, and then check to see how hot the compressor is. If it's real hot, try recharging.
1991 xj6 stalls when hot
Possibly running with a weak mixture. Look for air leaks in the induction system
Jul 30, 2016 | 1991 Jaguar XJ6
Maytag Performa Bottom Freezer, Compressor buzzing.
compressor pulling locked rotor. what your hearing is your current relay energizing. compressor goes off on internal overload protection and then tries to restart a few minutes later. unfortunately compressor needs to be replaced. sometimes a hard start relay will free rotor up. it can be purchased at a refrigeration supply house.
Jan 23, 2010 | Refrigerators
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
After driving for 15 minutes truck stalls,restarts no problem ,but trans races and stalls again. if it sits idle for 2-3 days runs again no problem ,until the 15 minute drive again .the 15 minute drive...
put a OBD II code reader on it see if it has stored any codes if not replace the TPS sensor and the MAF sensor do the replacements at different times so you don't buy one or the other for nothing
Jul 03, 2009 | 1993 Ford Ranger SuperCab
Engines stalls after 5 minutes from starting, then won't restart
the most common cause of a stall like u are discribing is the ignition control module.
Apr 11, 2009 | 1992 Honda Accord
Electrial problems never saw this one
sounds like the alternator has stopped charging or has bad connection at battery
Dec 08, 2008 | 1992 Dodge Grand Caravan
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
Coleman Mach 15 Air Conditioner Logo
143 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
