Question about Sony STR-DE545 Receiver
Sony STR-DE545 5.1 not working
I have the receiver set up correctly and all options are working except for the 5.1 surround. Even with 5.1 selected on the front of the receiver, it still does not work. I have tried everything I can think of. Hopefully someone has a solution before I purchase something new......
  • Anonymous Dec 06, 2007
    center speaker cuts in and out
Are you connecting from your DVD player to receiver using an optical cable or simple AV cable?
Posted on Jan 03, 2008
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
Cant get the surround sound rear speakers to work
Page 16 and 17 of the manual available at retrevo.com discuss setting the Center and Surround Modes and volume.
Select a Surround Field Surround Mode Function.
Dec 23, 2010 | Sony STR-DE345 Receiver
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Mar 24, 2010 | Sony STR-DA1000ES Receiver
I can't get the speaker B option selected on my Sony STR DH800 7.1-Channel Audio Video Receiver
If you're using the terminals for Surround Back (7.1) there is no Speaker B option.
See the notes on page 19 of the manual.
Mar 03, 2010 | Sony STR-DH800 7.1-Channel Audio Video...
I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Nov 29, 2009 | Sony STR-DH700 A/V Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Need instruction on how to set up to surround sound.
Go to www.sonystyle.com click on "support" Type in your model # and you will get more information the you could ever need on that receiver! Including the manual. Hope this helps!
May 22, 2009 | Sony STR-DE697 Receiver
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Sony STR-DE545 Receiver Logo
159 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
