Question about Brother HL-2040 Laser Printer
Toner isn't too old and drum light is lit on brother 2040.
SOURCE: HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Posted on May 12, 2008
  • 13 Answers
SOURCE: brother hl 2040 printer
This indictes its time to relace the drum.(drum life is up to 1200
copies)
mongrelken.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
Posted on Jun 10, 2008
SOURCE: BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Posted on Nov 06, 2008
jvernice
  • 63 Answers
SOURCE: Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Posted on Aug 08, 2009
I have a Brother HL 2040. I placed a remanufactured drum and toner into it. The Drum light keeps going on. From various sources on the internet, I learned that I am supposed to reset the white counter on...
Here is the drum counter reset procedure.
Good Luck and Thank You for using Fixya.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Sep 25, 2010 | Brother HL-2040 Laser Printer
How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Apr 10, 2009 | Brother HL-2040 Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
I have a brother HL 2040 laser printer. The toner and drum light were lit, so I replaced both the drum and the toner cartridge, but the toner light remains on. I have tried everything, but the toner...
Two things I could suggest you check. First, make sure you have removed all packing from the drum and toner. Sometimes there is a plastic strip on the toner that has to be removed before installation. Also, make sure you are using a Brother brand toner. Some generic brands do not replace the chip in the cartridge and they will not work,
Sep 19, 2008 | Office Equipment & Supplies
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Aug 22, 2008 | Brother HL-2040 Laser Printer
REPLACE DRUM BEFORE TONER'S OUT?!
hmmm...and there is no functionality? I recommend a new set of drivers first from www.brother.com
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Brother HL-2040 Laser Printer
Apr 06, 2008 | Brother HL-2040 Laser Printer
BROTHER HL-2040
I think the previous post applies to resetting the drum light after replacing the drum.
You need to reset the toner end-of-life condition.
  1. Open the Front cover
  2. Press and hold the GO button
  3. Power ON the printer while continuing to hold the GO button
  4. All 4 LED's will light up and then 3. Once the 3 LED's are lit, release the GO button
  5. Press the GO button 2 times. This will cause the
    LED's to light solid
  6. With the LED's lit solid, press the GO button 5 times
  7. At this point the Paper light should be blinking. Toner end-of-life has been reset
  8. Close the front cover.
Dec 10, 2007 | Brother HL-2070N Laser Printer
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
PROBLEM BROTHER 2040 PRINTER
Have you replaced the drum and toner? It sounds as if the printer is saying it's time. The motor constantly running usually means it's trying to add toner to satisfy the toner sensor, but it's empty.
May 29, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
37 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
