Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
File allocation showing 64.0GB, Not formating
I have transcend flash dirve 4GB, I am trying to use its showing you have to format, when I am trying to format, msg says your flash drive is write protected, could you please sholve this problem..
Thank you
  • mchs_lib Jun 28, 2009
    I am sorry sir there is no switch, How I can remove write protection..
    Scholar:
  • 106 Answers
If you inspect the Flash drive, you will see a little sliding switch on it. Slide the switch to the other side. Now, try inserting the Flash Drive and you will have write access.
Posted on Jun 28, 2009
My 4gb memory card showing 30.1mb and can't formatted
My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
Jul 23, 2014 | Transcend TS4GSDHC6V 4GB Micro SDHC Flash...
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a transcend jet flash v33 4Gb. I save files in it and then safely remove it, the next time i access the file it is already corrupted. I tried to format the usb but it still have the same problem....
Cause of damage is bad sectors
Transcend repairing bad sectors, you can see my blog.
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". View the the video tutorial "Repair Transcend Bad Sector"
Oct 02, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4gb pendrive was unable to format .While formatting option ,it shows only 8mb
Try to format with NTFS option. Sometimes FAT32 file system has a problem with big memory stick. Around 4 GB is FAT32 limit. Or maybe flash has some hardware failure, because memory cells from flash card has limited write cycling. Some of them have controller for using of good parts, but sometimes it has too much bad sectors.
Aug 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I formatted my 4GB TDK flash drive, now it show me only 3.95MB memory only. how can i recover it back to 4GB memory space, now it doesn't show me even the flash drive lock status & that screen when...
there is an overhead for the space on a drive, the system needs a File Allocation Table and other administrative information, so the total 4 GB is usually not 100% available. It would not work properly without this "administrative" space.
Jul 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I m not able to open or format my 4gb transcend
try using this software to format it..www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Jun 04, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't format my 2 gb transcend pen drive it saya write protect
Some usb drives/flash drives have a little switch that locks it and makes it read only to avoid accidentally losing important files. Try looking for a small switch somewhere on the case of the drive and switch it to the other position if you find it.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
81 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
