Question about Samsung TXN3245FP 32" TV
No power turn off, later not turn on, the LED is off, inside the tv i can hear a click, noise like a clock, click, clik, clickthank you I have the same problem exactly as described please help as i cannot afford to pay to get this fixed.Thanks in advance
  • dtfra Nov 09, 2007
    how hard is this to change
    no offense but I would like another opinion
  • 934 Answers
Dtfra,
Check the HOT (Horizontal Output Transistor) for short E-B. You can do this with a DMM or analog multi-meter set to continuity. The HOT has three legs, Base - Collector - Emitter and are marked on the board. Test for cont. between Base and Emitter and if you get infinite it's shorted.
The markings on the IC is J6920 and is Samsung p/n# 0502-001230. You can use a 2sd1880 in it's place to test run the unit but not for any prolonged period of time. A better cross reference would be 2sc5412 if the original part is B/O or not available.
If the HOT is shorted it will feedback and loop the shutdown circuit as fast as it can pulse the primary relay- thus the click, click, click...
Posted on Nov 10, 2007
  • William Rayburn
    William Rayburn Nov 17, 2007
    Not hard to change, just make sure that you use sme heat sink compound on the new installation and don't over solder..
    It's not that expensive to take it into the shop and have it done either... If you have ANY doubts going into this by all means take it to a qualified professional...
  • 790 Answers
Hi
the noise you hear is the RELAY circuit. the relay try to power up but they cant, because the oscillation circuit is defective thats why your power is not coming out! the main problem is the hot side section, the problem is the oscillation circuit.
Posted on Nov 07, 2007
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
Nov 10, 2017 | Samsung Televison & Video
My TV cliks and cliks but never turns on , What should I do?
That clicking sound you hear is your TV's power supply not getting enough current to turn on the screen. Could be as simple as a blown capacitor on the power supply board unit. Many TV repair shops just replace the whole unit, I am almost sure that is your problem with you TV as I've had the same problem with several TV's before. That clicking sound always points to a power supply gone bad.
Feb 23, 2015 | Televison & Video
2002 hd fat boy 1450 kiryakin air filter vince hines 2in1 pipe 16000km my problems is on the left side on both top valve cover theres a clicking noise coming from there more likely when the engine warms up...
What you're hearing is the rocker arm opening the valves. This is normal operating noise.
Your Harley is an older design pushrod operated engine. Unlike most other motorcycles engines, Harley does not use overhead cams in any of their bikes other than the V-Rod. Additionally, there is no sound deadening material inside the rocker box covers. Although the engine is equipped with hydraulic tappets, there is a bit of running clearance in the rocker arms and their shafts they run on.
In short, this is not unusual and your Harley will run for many miles. If you can hear that clicking, it sounds like you need to take the baffles out of that V&H pipe.
To see a diagram of your engine, go to BikeBandit.com. , click on OEM and choose your bike or any Big Twin of that year.
Good Luck
steve
Sep 29, 2010 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, TV dead and the relay on the power suply cliks once
Did you replace these Items?
IC1509(V out) i
Q1505(V Pulse Buffer)
Jun 18, 2009 | Sony KP-53S75 53" Rear Projection...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Samsung TXN3245FP 32" TV Logo
168 people viewed this question
Jerry Greenberg
Jerry Greenberg
