Question about RCA D52W19 52" Rear Projection Television
Hello I have a 52' RCA tv 4 years old, the model # is d52w19. When I turn it on it makes a loud ringing noise and goes away after 5-10 mins every day when I turn it on. What can I possibly do to make the t.v work like new again!!?? Please email me back if this is not instant. Lyfe_on_line@hotmail.com Thank you in advance Doug Fowler
  • 1030 Answers
SOURCE: RCA 52" Model # D52W19
when the processor on the set detects a problem it will shut the set down for safety. it could be many things. technicians have a device that can read the errors that the processor has detected.
Posted on Dec 20, 2007
  • 92 Answers
SOURCE: RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Posted on Jun 09, 2008
SOURCE: RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Posted on Sep 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
  • 115 Answers
SOURCE: 52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Posted on Sep 28, 2009
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
Green lamp goes out within minutes of turning on tv
Check CRT board the Video IC on it can be bad so you do not have to replace Tube be Very carefull when you remove CRT board from Neck of Green Tube so you do not Breck it. Check all 3 tubes make sure none of them are leaking out coolent fluid.
Jan 01, 2009 | RCA D52W19 52" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
52 in rca D52W19 turns on and then turns off. This has happened before.
Do you still need help with your televisions? RCA is having alot of troubles with these tvs.If you are still in need of help reply back. Thank You for using FixYa and Have a Nice Day.
Dec 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
