Question about Nintendo Wii Console
Can not connect to internet ( wireless ADSL). In the manual it looks like you go through a process of informing it where or not you are wireless ADSL or not but this does not come up screen
  • 432 Answers
I never knew the wii was wireless from what I was aware you would plug a network cable into the back of it and connect that to your router and even if it does have wireless the connection speed would be rubbish so you are better off if you can ( assuming it has a network port on the back of it ) to connect it via a network cable.
Posted on Jun 28, 2009
Wireless router is not connecting to pc even via network cable, all lights are on except 'internet' light.
Absence of an internet connection suggests a missed step in the set up process. (Apologies if you have tried this) the ASUS manual has a very good diagram to help with this
http://content.etilize.com/user-manual/1020184143.pdf
Jun 17, 2014 | ASUS DSL-N10 Wireless-N ADSL Modem Router
Hi, I have a DSL-504T ADSL router that has been running without any problems for some time. I just bought a wireless Dl-624S router. I have been unable to connect the wireless router to my ADSL router.I...
Freind,
You should have a look on manual, if you don't have just goto the manufacturer's site and download a manual for your product.
I think it will help you in a better ways.
Thanks
Iqbal
Apr 22, 2008 | Computers & Internet
Adsl link does not become stable, it shows blinking orange light
Reading the manual Troubleshooting section it looks like your adsl connection is not working. Try unplugging your internet provider's equipment power supply and waiting 10 to 15 seconds. Then plug it back in.If this doesn't work contact your ISP.
Mar 06, 2014 | Belkin Computers & Internet
Describe your cannot connect my cga5722 wireless
well you need to reset your router wireless config, your isp dont do this, you need to config yourself, but i give some help. try these manual steps:
4.1 Log on the webpages
Open your Internet Browser
Enter http://192.168.2.1 in the address field
Click on GO
• The following webpage will be displayed
Note
The only default language is English.
To access the required webpage, click on the corresponding tab on
the left side of the page.
4.2
Webpages’ menu structure
The table below describes the menu tree of the webpages.
4.3 ADSL/Internet Settings webpages
4.3.1 ADSL status
Click on "ADSL Status" which is located on the left side of the screen.
SET UP WIZARD Getting started
Wireless settings
ADSL settings
Confirm
The ADSL Wireless Base Station also operates as a wireless access
point, allowing wireless computers to communicate with each other. To
configure this function, you need to enable the wireless function, define
the radio channel, the domain identifier, and the security options.
Check Enable and click "SAVE SETTINGS".
You must specify a common radio channel and SSID (Service Set ID) to
be used by the ADSL Wireless Base Station and all of its wireless clients.
Make sure you configure all of its clients to the same values.
Access Control allows users to define the outgoing traffic permitted or
not-permitted through the WAN interface. The default is to permit all
outgoing traffic.
If the signal strength of a single wireless base station is not sufficient due
to a large coverage area or attenuation due to walls, with WDS the
range of a wireless base station can be extended.
All base stations in a Wireless Distribution System must be configured
with the same radio channel, and encryption type (WEP/WPA) if that is
used.
i send a link for these steps more datailed on:
http://download.p4c.philips.com/files/c/cga5722_05/cga5722_05_dfu_eng.pdf
Jan 16, 2010 | Computers & Internet
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Nintendo Wii Console Logo
48 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
