Question about GE Heating & Cooling
The fan in my outdoor ac unit will not turn - GE Heating & Cooling
  • 156 Answers
First, go outside and see if there is a reset button on the unit that the fan is in outside. Push it to reset.
Posted on Jun 28, 2009
Air conditioner outside fan does not turn off
Is the compressor shutting down and fan is not??? How about the blower, is the coil freezing? Need to check the contactor on the outdoor unit, 240 volts hurts, please use caution. If not confident as to what you are doing call a professional. If need be turn off breaker, you do not want the coil freezing inside!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Heating & Cooling
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Air conditioner just conked out;only 3 yrs old
Is the indoor unit operating? If no turn the fan from auto to on at thermostat. If the fan comes on, that is a sign that you have 24volts
present on thermostat side.
Turn AC unit off outside,turn the thermostat as low as it will go. Open the electrical panel to the outdoor unit. There is a contactor located in the unit, push the plastic bar in the middle of contactor. If it pushes
in, you have low voltage wiring problem from the outdoor unit to the
indoor unit.
If you are skilled or know somebody that is with electrical, turn the power back on to the outdoor unit take a non conductive object and
push the contactor in, the unit may start. If it doesnt start,check the
breaker for the ac unit to make sure it is not tripped.
If the breaker is not tripped and the condensor fan comes on and the
compressor does not come on and the breaker does not trip, then it
is very possible that you will need a new capacitor and while you are
at it put in a hard start kit.
This unit according to you, still should have 2 years left on the compressor warranty.
Jun 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Ac unit breaker trips off
First thing to do turn off the breaker in the electrical panel, then open up the AC outdoor unit, including the disconnect box, that should be mounted on the wall near the outdoor unit. Go thru and tighten all of the screws and wire nuts, look for burnt wires, while you are at it.
Turn on the breaker and try again, if it still trips, then we look deeper;
pull the control panel off the outdoor unit and look for the contactor, this is where the power coming into the outdoor unit hooks up to. There will be a set of contacts in the control, check it out and see if the points are badly burnt,
If all off the wire checking still has not helped, it will more than likely be a bad condensor fan motor or a compressor, the compressor is the big black thing in the bottom of the outdoor unit, making sure that all power is turned off, pull the plastic cover off of the side of the compressor, there will be 3 wires, make sure none of them are burnt and touching the metal, if they are, repair the wire and test.
Try this and if you need to know how to troubleshoot to see if it is the fan motor or the compressor, just contact me back.
If this has been helpful, please rate me.
Contact me if I can help you any more.
Sincerely,
Paul
Apr 10, 2010 | Goodman CKL24AR24 Air Conditioner
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
I have Goodman combination heating and cooling outdoor unit PBB series. I am wanting to know if when the heat is on should the fan outside turn or is that only ac
If it's a heatpump, then yes the outdoor fan will turn unless the unit is going in defrost mode. But for the majority of the time a heat pump is operating in heat mode, the outdoor fan is running.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
