Incorrect valve adjustment, especially on OHV motors that causes a backfire can cause the sheer pin to break. Obviously this saves the motor from worse damage. Also, sudden stops caused by hitting something like a log or stump with engaged blades have broken the pins before. On an older motor I had one sheer because the piston rod was a little loose off the crank and the slop was causing the motor to bind. Obviously this did internal damage but the sheer momentum of the motor spinning a heavy flywheel no suddenly stopping broke the pin. Lastly, the magnets on the flywheel could be hitting the coil pack, binding up causing the pin to snap. Be sure to check if the space is gapped correctly. And don't buy cheap pins or generic pins. There should be no slop whatsoever. You almost have to pound it into the slot. Slop equals a much high ER chance of breaking for no reason at all.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
