Question about Acer (90.18612.36B) Computer Speakers
NO SOUND FROM SPEAKERS
I HAVE NO SOUND FROM MY SPEAKERS OTHER THAN A CRACKLE SOUND WHEN i TURN THEM ON AND OFF
  • 432 Answers
If this is an onboard sound card then you need to make sure that the jumper to enable it on the motherboard is in the correct position and its there ( sometimes when you get a motherboard they supply you with the jumper pin in a plastic bag but never actually install it so you will need to refer to your manual for this )
Also ensure its enabled in the bios / cmos.
If this is a dedicated sound card such as a PCI sound card then make sure the latest driver is installed and also finally ensure that the cable(s) are plugged into the correct ports ( generally green for audio out, pink for microphone and blue for line in which is generally used for if you want to connect a tape player or some external device to your computer and record from that excluding a microphone obviously )
If you are still having issues then I would test the speakers on a known working computer and if its still an issue then its down to the speakers or how the speakers are wired so if those are under warranty then get them replaced if not and they are old then maybe try and fix them yourself.
Posted on Jun 28, 2009
Sound on pc cracklin
Start by plugging in the green audio jack into an mp3 player or even smartphone and test the speakers. If they still crackle then I would say replace the speakers. If they don't crackle then try going to Dell's website, search your model and update your audio driver.
Dec 17, 2012 | Dell Dimension E520 PC Desktop
My logitech s-120 speakers crackle very loudly sometimes. At first I thought it was the sound card in my old PC, but when I switched to a brand new Mac computer the problem continued, making me think the...
hi there,
The problem is actually from the speakers themselves. If it's not a year old you might want to bring it back to the store where you purchased it for a warranty repair or replacement.
Sadly the problem is inside the speaker and it could be a loose connection inside. If you're comfortable enough you can try to open the speakers and check inside for any loose wires which cause unstability of sound or for any loosed fittings from the magnet.
Hope this helps!
May 30, 2011 | Logitech S120 2 Speakers
When i hit a bump, speakers crackle
if its a poping sound usually means speakers are going bad,crackling sound means the speakers are not grounded properly.this video might give you hint as to whats going on.
Jan 29, 2010 | 2006 Pontiac Grand Prix
Car speakers crackle even with thw volume all the
turn the bass all the way down if it still does it your speakers are bad or the deck needs replaced but its more than likley the speakers
Aug 10, 2009 | Car Audio & Video
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
Crackling Speakers
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
melnavz
Feb 10, 2009 | HP Computers & Internet
No sound coming out of speakers
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
Jan 22, 2009 | Kenwood VR-509 Receiver
My car sound system start crackaling when i turn it up. the sub sound fine but my 6x9s crackal and my standard door speakers. p.s only just starting doing it
Sorry to say but if your speakers crackle when you turn them up you need to not turn them up so much or buy new ones. That crackling sound is a blown speaker. It could also be a bad connection but most likely blown or under-driven speakers. Good luck.
-Andrew Hawkins
Aug 27, 2008 | Car Audio & Video
Sound prob
Let me know what the Type Numeric Number and Model Number on the bottom of the laptop is. I can look on IBM website and see where the hard drive is in located to the speaker. It has happen on some HP and Toshiba I know from experience where the hard drive causes the speakers to crackle. Not sure why, maybe not enough shielding. The type has 4 Numeric Characters and the Model has 3 Alpha/Numeric Characters.
Let me know
comier957
Aug 10, 2008 | IBM ThinkPad R40 Notebook
176 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
