Question about RCA Televison & Video
Rca hd52w59 3d color at first now just lines when it does come on
The color was 3d and now the tv will come on occasionally but mostly just show 3 fish eye lines or not come on. will the convergence fix kit solve the problem?
  • 1 more comment
  • wes_tennyson Jun 28, 2009
    i have read about a convergence thing in the menu . how can i access this?
    not sure if last question went through. how can i access the convergence function on the menu?
    how can i access the convergence menu on an rca hd52w59
    President:
  • 1,952 Answers
CA CTC111C: "adjust the center set of magnets to converge blue to green at the center of the screen. Adjust the rear set of magnets to converge red to green at the center of the screen." Your set may have a slightly different procedure. Dynamic convergence adjusts for coincidence at the edges and corners.
On old tube, hybrid, and early solid state TVs, dynamic convergence was accomplished with electronic adjustments of which there may have been a dozen or more that were not independent. With modern sets, all convergence is done with magnet rings on the neck of the CRT, magnets glued to the CRT, and by tilting the deflection yoke. The clamp in conjunction with rubber wedges or set screws assures that the yoke remains in position.
From the Sams' for the RCA CTC111C: "Loosen the screws at the 6 o'clock and 10 o'clock positions to permit the yoke to be tilted vertically. Rock yoke up and down to converge the right and left sides of the screen. Tighten screw at 6 o'clock and loosen screw at 3 o'clock to permit the yoke to be tilted horizontally. Rock yoke from side to side to converge the top and bottom of the screen. Tighten screws at 3 o'clock and 10 o'clock."
Many sets simply use the main clamp which locks the yoke to the neck of the CRT in conjunction with rubber wedges between the yoke and the funnel of the CRT to stabilize the yoke position position.
Refer to your service manual. (Is this beginning to sound repetitious?)
For additional comments on convergence adjustments, see the sections: "Tony's notes on setting convergence on delta gun CRTs" and "Saga and General setup for large CRT TVs".
Posted on Jun 28, 2009
  • 4 more comments
  • mohammed marika thambi
    mohammed marika thambi Jun 28, 2009
    Before you go and buy parts it might be worth your time to check the
    convergence power supply fuse. It's located in the back of the TV just
    to the right of a large black component with 2 red wires coming off of
    the top. This is the flyback transformer. Just to the right of the
    flyback you should see three fuseable links that look like chicklet's
    gum. The one that may have fried is the one in the middle, it's a 400mA
    125V fuseable link.
    The convergence of the three color guns is
    controlled by a pair (sometimes three) convergence ICs (integrated
    circuits). You can't miss these if you look inside your TV. They are
    huge and mounted to big heat sinks.
    What normally happens is they fail due to heat, sometimes at the joints, and take a few other components with it.
    To have this repaired by a pro will likely run you $250-$400.
    You
    can do it yourself for about $50 in parts and a couple of hours of
    labor. I should be able to provide the part numbers and you can go for
    it if you feel adventurous and have access to some basic tools and a soldering iron.
    http://www.justanswer.com/questions/198n...
    The convergence circuit is having problems. Since this seemed to
    "repair" itself on occassion, I'd first look for bad connections on the
    convergence ICs. These are large black ICs attached to a heatsink.
    They will have 15 pins or so. Resolder all of these pins
    This is a convergence problem and is either bad connections at teh
    convergence ICs or defective ICs. These ICs are large black Ics
    attached to a heatsink and should be marked STKxxx. Try resoldering
    the pins on these ICs first. If that fils to correct the problem,
    replace the ICs.
    mohammed marika thambi Jul 04, 2009
    It has failed and needs repaired. There are two Integrated Circuits
    needing replacement. The cost is always around $300 to $400. It is a
    common problem with big screen sets like yours.
    You can repair it by yourself if you have electronics training and
    experience. It requires knowing how to remove the ICs and soldering in
    the new ones.
    You can google around and find step by step instructions on how to do it for most models
    Well, first do the hard reset and whacking test just to make sure it is not something simple:
    ONE: Unplug the power cord for 4 hours. When you power it back up all the internal soft codes will restore to factory defaults.
    TWO: Whack the set with your hand all about; top, back, sides, etc.
    This will get any loose connection or cold solder joint to connect
    again and maybe bring it back to normal.
    If these two procedures don't help, then you can assume the problem is
    a serious one and that strong technical support will be necessary. I
    would say there are two problems acting up. 1) something in the
    deflection system and 2) a vetical blanking function that is operating
    at too high a frequency. Unfortunately, it is not something that you
    can diagnose at the home remedy level; it will require a tech who knows
    how to work on this model.
  • 297 Answers
Yes, this is surely a convergence problem. The convergence kit must solve it. Quite a common prob with most of the projection TVs.
Thank you!
Sabharish
  • sabharish
    sabharish Jun 28, 2009
    If you go into setup then convergence. then can you move
    crosshairs in setup. Since you have a blurry picture this indicates convergence
    power supply problems....in which has to be replaced or repaired,
    If you do NOT have the Convergence in menu, it could be a special
    small fuse.
    Look next to Flyback Transfomer thier is 3
    small looks like square brown caps they are fuses FL231 one of them is opened
    causing lost of convergences, when you go to menu and do not see convergence on
    that menu this is what causes it and will set off a convergence problem.
    Thank you!
    Sabharish
  • sabharish
    small fuse.
    Thank you!
    Sabharish
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
LG 47lv5500 shows wrong colors
Hi, Probably you are gonna have to change the main board! Best Regards! Bye!
Serge!
Jul 03, 2015 | LG 47 47LV5500 47 LCD TV
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
3 color curved band lines on my RCA tv.
Ur convergence is dead.U must know how to do soldering to fix this problems?Must replaced 2 STK convergence ICS,and some or all it resistors too.Tries websites Tv repair World.com,Tvrepairkits.com to do the reapair it ur self.The shop will cost U $300 for parts and labors.
Mar 20, 2010 | RCA R61WH76 61" HDTV
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scrolling Green color on screen
If the lines are like pin stripes going from left to right then you most likely have a defective green crt
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Televison & Video Logo
83 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
