Question about Mtd LAWN MOWER PART # 753-0698 KIT-DECK 42" NEW S
MTD Lawn Tractor problem
I have replaced idler pulley and belts with original factory belts on my MTD lawn mower model 13am675g062.It looks as if the front drive belt is not turning at the variable speed pulley, all belts are new, i think the belt from the factory is to long. It will move but as you shift into higher gears it creeps to a halt, any ideas?
  • 2 more comments
  • maximus1968 Jun 28, 2009
    I have done this and have got the correct belts per the manual they are belts 954-0370,954-0280A, and 954-0371A. I really think the 954-0280A belt coming from the motor is to big, I have also adjusted the linkage for the shifting per the manual. Somethings not right,im gonna try another belt thats smaller
    I have oiled it with WD-40 and it moves freely, I can see it pivot up and down, the front belt is just not turning inside the inspection cover above the vari speed pulley when you look down at it with the motor running and in 1st gear, 2nd gear etc.....
  • maximus1968 Jun 29, 2009
    Yes i can see all of that and have done as you stated, the back belt is showing alot of slop as its running and transfers to the higher gears....hmmmm
    It is hooked up, how much tension should there be? Should it be pulled in all the way?It acts like it is flapping on the left side of the belt looking down at it.Any ideas? Weak spring?
  • 376 Answers
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
  • 3 more comments
  • Dwain Pippen Jun 28, 2009
    You can try onother belt, but I can tell you it;s not going to work. There is a problem with what you have there. I suspect it your vari-speed pully. Can you see, for sure, the center of the pulley moving up and down and the whole thing pivoting back and forth as you let off the clutch and push it down?
  • Dwain Pippen Jun 29, 2009
    Ok.. Did you remove the bolt on the engine pulley and pull it down to get the belt on it? Then you would have to have taken the clip off the top of the vari-speed pulley and pull it up to get the new belt on the lower part of the pulley. You then would have taken out he two bolts that hold the gear shift support bracket to the side and slipped the rear belt over the shift lever and put the belt on the transmission pulley, idler pulley and vari-speed pulley. So, you did all that, correct. Now you say you can see the center of the v/s pulley move up and down as you push down and let up the clutch pedal. You can also see the whole v/s pully assy move from front to rear as you push down and release the clutch pedal?
    The rear belt never has slop as the idler is spring loaded and always keeps tension on it. Maybe the spring that is anchored underneath above the right rear axle is unhooked.
    Not sure what you're saying there, but the rear belt should be BETWEEN the idler and the trans pulley. The backside of the belt is against the idler and the 'v' side is on the trans pulley. Do you have the belt over the idler pulley. If you do, there is no tension being put on the rear belt.
    Enlarge this picture and look at the rear belt set-up.
  • 3 Answers
I got the same mower, and I had the same problem when I replaced the rear drive belt today. It's probably a good idea to replace both drive belts at the same time, because of the variable diameter pulleys, if one belt is worn thinner than the other, this could change the intended ratios.
However, I have noticed after running the mower around the yard for 30 minutes, the higher gears are working better. The variable speed pulley is a clever design, it can't hurt to oil the bearings, but you probably don't want to WD40 the actual belts.
Posted on Jun 04, 2010
  • 3 Answers
Try going to partstree.com
Posted on Jul 13, 2010
Gas in the oil pan
Posted on Apr 28, 2010
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to tighten mower belts on mtd hds cub cadet lawn mower
There is no 'adjustment ' to be made other than routing the belt correctly. The tension on the belt is made by the idler pulley which is spring loaded. If you can provide the model number of the mower, I will search for a belt routing and parts daigram.
May 03, 2014 | Garden
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
HI I HAVE A 16HP MTD LAWN TRACTOR LATELY EVERY TIME I GO DOWN A SLIGHT HILL MY DRIVE BELT FROM THE TRANSMISSION COMES OFF WHAT WOULD BE CAUSIN THIS PROBLEM?
The drive belt has become loose. It may have worn out and stretched, but first check that the idler pulley is in place (pressing on the belt to tension it) and that the spring (one or two) that tensions the idler pulley has not come loose or broken.
Aug 17, 2010 | Mtd Garden
How do I know if I am replacing my mtd rider mower belt correctly
The rule of thumb for the routing of the mower belts is to make sure the "V" inside of belt is fitted into your pulleys. The "FLAT SIDE" outside of the belts rides with the flat side up against your idlers (lookes kinda like a pulley but is wider.) It might take you a couple of attempts to get it right. When the belt is on properly it will be nice and snug.
Good luck
roundo4
May 23, 2010 | Mtd 22" White Outdoor Self Propelled High...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
How do you change Craftsman Lawn tractor model 917.272673 belt
it simple 1st lower mower deck 2nd take belt off of engine pulley then out behind the idler pulleys then the blade pulleys slide out & reinstall if i can further help you e-mail me wade at wadembly@aol.com
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Jun 05, 2009 | Mtd Garden
Mtd LAWN MOWER PART # 753-0698 KIT-DECK 42" NEW S Logo
3,525 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
