Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso - Will not start
My five year Calypso GVW9959KQ stopped working today. It has power, but it does not react to any buttons being pushed. The lights suggest it is stuck on the last cycle - Normal. When I push the Start and/or the Stop Cancel button nothing happens. It also will not change cycles if I press a different button. When I unplug - plug back in nothing chnages. Any suggestions? I hate the thought of calling a repair guy.
  • bds3086 Dec 08, 2007
    i have the same problem, pushed all the buttons sometimes it will respond, not today!
  • huskee33 Feb 15, 2009
    Mine just crapped out after 5 years as well! sounds like that is the life expectancy of what was suppose to be such a great washer.
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
Posted on Dec 17, 2007
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Posted on Nov 12, 2007
  • lullguy Nov 12, 2007
    Read my experience under "CE code on 6 1/2 year old Calypso" before you fix anything. This goes for all you fellow Calypsoites.
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine will not turn on. The
There is a recall on the electronic controls on this, contact Whirlpool corp via their website and call customer relations. They will issue a concession for parts and labor to have it replaced.
Mar 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Control board malfunctioning.
You can try tripping the breaker a half dozen times or so, or else leave it unplugged/without power for a couple days. Once it is plugged back in you may have to leave it overnight and then try it, but that almost always revives it. I notice the problem when I don't use the washer/dryer once a week or don't push any buttons during that time to activate it in some way. Problem seems to occur more frequently in the winter when house is cooler.
Feb 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Top-Load Washer gvw9959kq
Yes. I replaced the control panel (the panel with all the cycle buttons on it). I downloaded the technician's manual from whirlpool and went through the troubleshooting to find the problem. Th part costs around $106.00. Just make sure you order the right color.
Jul 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
5L error code
I will pull the book and get back to you today
Jan 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
1,022 people viewed this question
Dan Webster
Dan Webster
Sal De
