Question about ASUS WL-500g Premium Router
Assus WL-500gP router hangs
Router hangs. All the LAN diodes and the WAN diode on. Could not reset it with the reset button
I had the same problem and found the solution here (last post):
http://wl500g.info/showthread.php?t=11077
Short answer: "the power supply is faulty"
Posted on Sep 02, 2009
  • Keoni Jun 24, 2012
    Thank you so much for the answer. As a troubleshooter I'm embarrassed to admit I missed something as simple as measuring power intensity... I've had this problem for some time and of course took the easy way out of purchasing another router. Buying a new power supply with 5V/2.5A fixed the problem! Again thanks for the valuable lesson!!
  • 432 Answers
Purchase a new router made by linksys, draytek or netgear.
Posted on Jun 28, 2009
SOURCE:
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Not sure what really happened, but it appears that my ASUS 500g Premium router is frozen. Was working fine yesterday, but not today. LAN 1, 2, 3 and 4, and WAN lights are all on. Power and AIR lights...
reset the router, push the tiny reset button. If it doesn't work, call your ISP (if it's a modem/router) ...or if it's a secondary router, get a new one?
Jul 21, 2017 | ASUS WL-500g Premium Router
Hi, I used WL-500gP V2 router. It was working okay with original firmware. However, since I upgraded to Version 3.0.4.4, the system always shows that it has wrong ip address and ask to reset dynamic or...
Have you attempted a hard reset? There is a small button on the rear or bottom of unit. Depress that for 10 or so seconds and the unit will perform a factory reset. Try that to determine if it will remember the recent downloaded firmware.
Feb 23, 2018 | ASUS WL-500gP V2 Router
I don't remember the password to my wireless router: Asus WL-500gP V2. Is there a way to find it or reset it?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Sep 12, 2010 | ASUS (wl500g) Wireless Router
Resetting router password?
Aug 11, 2010 | ASUS WL-500gP V2 Router
I need to reset the password and get a netwrok key
you can reset your router with reset button for factory set and then you can access you setting area with 192.168.1.1 IP Address
Apr 06, 2010 | ASUS WL-500gP V2 Router
My asus wl-500gP v2 can't connect to the wan properly... I get the message "you have set the wrong dynamic or stic IP address for you WL-500gP V2." I'm confused because I have it set to dynamic which...
Your ISP address is dynamic, which means every time you log on to your ISP, your WAN IP address changes, this helps to stop hacking. Your ISP even though it is cable uses PPPoE/PPPoA, so you should set your router to this, not dymamic, setting your router to dynamic will make your router look for a different IP address every time your computer tries to log to it, your computer should have e.g 192.168.1.2, which is static, you can check this by going to command prompt and typing ipconfig, see what it brings up. hope this helps and post back if you need further help.
Apr 03, 2010 | ASUS WL-500gP V2 Router
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
ASUS WL-500g Premium Router Logo
1,962 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
