Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Blinking Lights Kitchenaid KUDP02FRSS - KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
Does not clean dishes
if you have had it for a while, you need to clean it with a dishwasher cleaner. you can find it at wal-mart or k-mart. mine was the same way after about a year.
Feb 15, 2012 | KitchenAid 24 in. KUDP02FRSS Stainless...
I have a kitchaid dishwasher model KUDP02FR. When I press normal wash and heated dry, then start, the green light keeps flashing and will not start. Any suggestions? I had a repair man here in August for...
There are a couple of possible ways to reset the board. Pressing the keys HEATED DRY - NORMAL - HEATED DRY - NORMAL. I forget how many times, but all the lights should come on and it will do a diagnostic cycle.
It may work with the HI TEMP SCRUB, ENERGY SAVER DRY, HI TEMP SCRUB, ENERGY SAVER DRY keys depending on the machine.
I don't remember if the door is closed or open when entering the sequence. Try both.
Mar 27, 2017 | KitchenAid 24 in. KUDP02FRSS Stainless...
Blinking lights, not washing
Usually blinking lights are indicating bad touch panel buttons. Remove kick plate, (black panel under door) and find service instructions there. It will tell you how to test button panel, as well as any codes flashing. Also will tell you hot to try a reset.
Jul 21, 2010 | KitchenAid Dishwashers
My kitchenaid dishwasher is leaving a white film on all my dishes no matter what setting i use.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 09, 2010 | KitchenAid 24 in. KUDP02FRSS Stainless...
Is it common for Kitchenaid dishwashers to have water pooling inside them? It's almost like the valve for water coming in isn't shutting all the way...in the middle of the day, we'll find water inside the...
There is a rubber flapper valve that keeps water from running back into your dishwasher. It's a $5.00 part, but it's a bear to get to,
You have to pull the drain pump to access this flapper.
Also, be sure your air gap is clear (usually the silver tubular gizmo on top of the sink.
Jun 09, 2009 | KitchenAid 24 in. KUDP02FRSS Stainless...
All lights blinking on my blender
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available.
This error was probably not caused by replacing the coupler, but merely coincidence.
You may find a Kitchenaid certified service location using the following link:
http://caservice.kitchenaid.com/
If this is not helpful, I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Nov 28, 2008 | KitchenAid KSB5 Professional Stainless...
Kitchenaid help
Aug 21, 2008 | KitchenAid KSB5 Ultra Power Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
67 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
