Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
How to Fix Blinking Lights on Control Panel? - KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
My lights will NOT stop blinking on the dryer, the filter is absolutely clean and will not dry, and the lights are still blinking
Hey friend, thank you for your post!
From my understanding the panel on your Electrolux dryer is blinking and will not dry. It sounds like a potential problem with your control panel or sensor. I would perform a reset on your appliance which you can do by unplugging the power cord or flipping the household circuit breaker off for ten minutes.
If you continue to experience the lights blinking on your display the control panel or sensor may need to be replaced and I would recommend seeking assistance from a professional service technician for proper exchange of electrical components. -Matt
Oct 07, 2014 | Electrolux Dryers
BLinking panel lights will not turn off
Specifically what lights are blinking? Do you have the child-lock (control-lock) turned on?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | Jenn-Air Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher won't go on
The electronic control is bad; probably not worth the expense to fix as the next thing to go is the touch-pad.
Nov 28, 2008 | Frigidaire Dishwashers
Two blinking lights on top
lights on my asko dishwasher start blinking into the cycle
Nov 18, 2008 | Dishwashers
I have a quiet partner 3 dishwasher it keeps blinking normal and I can't get it to start. Help can't find book.
If a whilpool dishwasher starts blinking one of the lights all the time the touch pad is stuck. The key that goes with that light is not working properly. The only fix for that is to replace the control panel.
May 19, 2008 | Whirlpool Dishwashers
Blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Apr 26, 2008 | GE 24 in. GLD5860LSS Stainless Still...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
57 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
