When the w810i won't turn on anymore, the best solution is to try the Sony Update Service, that will find your phone and rewrite the code it needs to run, even though the phone won't start.
You can activate the bluetooth settings on the phone as well as on your PC , now once accepted you can send the files from the PC to the phone, only get the set passcode accepted. if connecting cord is available link up and transfer.
You must download PC suite first in order to read sms of your W810i on our computer.Things that you require are:
Data cable.
Phone monitor :It is the PC suite for Sony Ericsson W810i that will allow you to do task like reading SMS on your phone managing them,contacts and data etc.
You can download PC suite from following link: DOWNLOAD PC SUITE W810i [43.9 MB] Installation instructions:
Download the file to a temporary folder on your PC.
It is recommended to uninstall any previously installed version of Sony Ericsson PC Suite
Execute the downloaded file.
If
updating to a newer version of the Sony Ericsson PC Suite, a restart of
the PC may be required after the new installation is completed.
How to use:
Connect the mobile phone to your PC using an applicable connection: Cable, Infrared or Bluetooth connection.
Start the included programs from the Start/Programs/Sony Ericsson folder or the Application Launcher application
When I had the white screen problem, I was about to replace my W810i
before I found out about the Sony Ericsson Update Service (SEUS). I
used it to fix the firmware inside my phone, even though the phone
seemed dead and my computer wouldn't recognize it. You can download the
SEUS from Sony's website here:
To put music on your W810i cellphone, connect it to your laptop with the usb cable. If you don't have the cable use a memory stick. The phone or card will show up as a removable drive on your computer in the Windows Explorer. Copy folders of music into the MP3 directory. When your phone is disconnected or the card is inserted, it will take several moments to index the music, and then your music will appear in the music listings.
connect your phone to an pc using ur data cable which is provided along with the phone and then switch your phone to file transfer mode. the phone memory and memory card will b displayed as an removable drive. then scan these on the pc by a good antivirus. this will take care of all ue viruses. most of the mobile antiviruses are **** an they dont work.
i myself have an w810i and a scan my mobile with thismethod only.
update ur phone tru the SE website, then reload the software on ur comp..try connecting with the usb, follow wizard, and once u r connected, while disconnecting eject properly as the manual tells u to..All the best
