Question about Samsung LN-S4051D 40 in. LCD Television
NO VIDEO MY TV ONLY ON THE LIGHT THE SET NO VIDEO NOT MENU NO SOUND
  • 80 Answers
This happen pnly if your power suppy unit in your tv is not working properly, so kindly check your tv's power suppy unit.. thank you.. plz rate me..
Posted on Jun 28, 2009
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
    check to see if with a rear audio/video input you have sound (DVD etc)
    look in menu speakers are not set to off or external
    try the reset: Menu 1,2,3, enter.
    Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
    Sound problem
    If sound works from a video the audio circuit is ok--leaves only that something in TV mode is set wrong---possible but not real likely a headphone jack issue or in menu set may have a feature for turning speakers off in that mode or look to see if set has the SAP mode on the remote.
    If using a box of some kind issue can also be coming from it.
    Jun 16, 2012 | Televison & Video
    My ps3 has no video but the sound works i can here the menu when scrolling through it ive tried the reset and it lets me pick my settings but then when its done it still has no video any help is welcome...
    Try to reset the video settings on the PS3 and also make sure the cables are all attached and that you have the TV on the correct input source.
    Turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
    That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up.
    If there is anything else please post back.
    Regards.
    Jan 07, 2011 | Sony Playstation 3 (PS3) Console
    The Yamaha RX-V463 AV does not playsound from the blue ray player
    "I am also having difficulties in try to display the yamaha set up menu on the tv."
    According to the manual the display menu for TV will not work with HDMI hook up.
    I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
    Apr 07, 2009 | Yamaha RX-V463 Receiver
    My new Harman/Kardon AVR 154 has no sound and the blinking light cannot be fixed because I cannot get the OSD blue menu to come up on the TV screen from the remote.
    Do you have your receiver output connected to the input on your TV? For example, if the receiver is in connection number 1, is your TV set to connection 1?
    Dec 29, 2008 | Harman Kardon AVR 235 Receiver
    P52151WK 52" projection TV, no video
    Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
    Aug 26, 2007 | Televison & Video
    Samsung LN-S4051D 40 in. LCD Television Logo
    94 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
