Question about Sony KDS-R60XBR1 60" Projection HDTV
Red Lamp light went on . I just installed new lamp. Standy light was going on so I finally installed new fan that I bought a while back. Now system shuts down and standy is blinking 3 times. KDS-R60XBR1
  • j49erbw Jun 28, 2009
    Thanks for the response. My problem is that now that a new fan is in and a new bulb (only) the stanby red light is blinking 3 times which appears to mean the bulb door or the bulb itself is not secure. I have removed and replaced the cartridge and resecured the door several times but nothing works.
    President:
  • 987 Answers
KDSR60XBR1, 3 blinks, pause, 3 blinks, etc. means that the lamp door is open or that the switch that detects that it is closed is not acutated. Check the lamp door.
or
the below may be the problem
+B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board).
Posted on Jun 29, 2009
  • 297 Answers
Usually, when a lamp fails, the lamp capsule explodes and the LAMP light will illuminate on your set. Sometimes, a lamp will age and not explode. The reflector becomes clouded, converting the light into heat, which causes the lamp to draw too much current. An old lamp capsule usually draws more current than a new one, and the additional heat and added current draw eventually triggers a reset cycle on the TV (the loss of picture and green light flashing that you have seen). As the lamp cools, it will be allowed to restart and then the cycle resumes. Replace the lamp with a good quality replacement.
You lamp is available two ways. The first is the lamp assembly, whcih is the bulb and the housing. You can purchase one by clicking here
The seond way is to purchase just the bulb. You will have to disassemble your current lamphousing, remove the old bulb and install the new one. It is a bit more work
, but it is also less expensive. You can purchase a bulb by clicking here
If the problem is not fixed yet, then IC501 is faulty (G board), IC5002 is faulty (G board).
Thank you!
Sabharish
Posted on Jun 28, 2009
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
The red light was on solid, and the manual said to replace the lamp. I bought a new lamp and put it in, but still no picture. The fan comes on, it tries to power up and then in about 20 seconds the red...
these TV's have lots of problems. Don't waste your money on repair. But towards new one or you will be constantly replacing parts.
But anyway sounds like a power supply or light eng problem. If all measurements are good then the chassis needs to be sent to Mitsu for repair (approximately 140 updates to it).
Feb 26, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Aug 13, 2010 | Sony KDF-50E2000 50" HDTV
Red light blinking 3 times on Sony xl2400 lamp replacement
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
Aug 28, 2009 | Sony (XL-2400) Projector Lamp for...
Good sound, no picture, green standy light flashing
Replace the lamp-mine just went out also and sony told that I just need to replace the lamp---after a while the lamp indicator light will turn on red if and blink if this is your problem....also note to make sure it is your lamp unplug your tv from the wall or surge protector for atleast a minute or 2 and then replug it back in and see if the lamp light blinks red? If it doesn't then you got something else wrong. I hope this helps...if you need further assistance contact sony online via chat at sony.com and they'll help you fix the problem in no time. Take care
Mar 30, 2009 | Sony XL-2100U Projector Lamp for...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Feb 21, 2008 | Televison & Video
Sony KDS-R60XBR1 60" Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
