Question about Tech Solution TS-8000 Cross-Cut Shredder
Executive EPS-1501 X Shredder automatic sensor doesn't turn off
I would like to try to fix this myself - I used to be able to "fix" it by using the canned air to blow off any "paper dust" on the sensor. How can I fix without having to turn off machine with power switch? Thanks so much.
  • RonLewis Feb 07, 2008
    I have the same problem with two of these machines!
  • Anonymous Nov 16, 2008
    Thanks for the tip. I have this exact model and rubbed the front and rear sensor lenses with a rubbing alcohol dipped Q-Tip, and viola, it now turns off!
  • 102 Answers
Do not use any aerosol based or petroleum based products in your shredder as this could cause a fire. I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pcExecutive EPS-1501 X Shredder automatic sensor doe - 1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
Executive paper shredder eps-711x wont shut off
around the middle of the cutters there is a small lever that operates a microswitch
that level gets jammed in the on position from paper scraps and keeps the machine running
remove that paper bit and the machine will switch off
May 23, 2016 | Shredder Office Equipment & Supplies
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Does not auto shut-off anymore?
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Apr 06, 2015 | Cross Executive EPS-1501X Shredder
How do I oil my executive machines eps-1501x paper shredder
Oil the shredder blades. Refer to this article:
Mar 02, 2015 | Shredder Office Equipment & Supplies
My EPS-1501X has photo sensors that stops the motor from running when the paper reaches a certain height. How does this regulate the overflow?
From what I have seen on mine, there are three sensors: one to detect if the door is open, one to detect when the unit is full, and one to detect when material is fed.
As for mine, the unit would not start when it was fed. Once I opened it, I saw the photo sensor was missing a screw. I realigned the bezels and added the screw. However, once I reassembled it, the unit still had the same issue.
Now, I suspect that it is the control board. I have no time to get into that, but it does not look too difficult.
I searched the internet for support, but there seems to be no company presence available. So, I think I am stuck manually triggering and stopping the motor.
It is an amazing shredder otherwise and I would not even consider replacing it. At least, not until the motor fails.
From what I have seen inside, I doubt that will be anytime soon...
Jan 03, 2014 | Cross Executive EPS-1501X Shredder
Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
Dec 10, 2013 | Executive Machines SESS640HD 6-sheet strip...
Executive Machines EPS-1200X Shredder has power but papers are stuck and there is no sound from motor
You will need to clear the jammed paper using tweezers from between the rollers. Make sure the sensor arm in the middle of feed opening is not stuck and moves up and down freely. If not you will need to give it a good soak with lubricant to allow any stuck paper to soften and loosen. Once cleaning procedure done unit will be good as new
Oct 13, 2013 | Staples Executive EPS711X Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
780 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
