Question about Jenn-Air JCD2389G Side by Side Refrigerator
Door inner edges Hot (center)
The inner edge of both doors (center) are HOT, otherwise seens to be workind fine
  • 473 Answers
This area is called the mullion and should be a little warm so it doesn't sweat. If it is too hot then two things could be the problem. 1. The condensor is plugged (dirty) and needs to be swept out. 2. The condensor fan motor is not working. This cools the condensor coils and is mounted in the back of the fridge behind the bottom panel.
Posted on Nov 07, 2007
Westinghouse WSE6100SA*1: reset button beeping, door edge is hot
sounds like the defrost timer has quit in the on position.
Dec 20, 2014 | Westinghouse Washing Machines
Whwhat causes side-by-side freezer/refrigerator center partition to be hot to the touch?h
you got a short in the wiring from frig to the door get it checked stuff like that can burn your house down.
Jul 30, 2014 | Maytag Refrigerators
The left edge (about 12"
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101;
Jul 28, 2011 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
Overheating ... the rubber edging on the doors is very hot
The rubber edges on the door are suppose to get hot.
some times the fill very hot. many people don't notice this. There is a small mullion heater plased around the doors so that the gasket will not freeze and the door will stick and not open.
Jun 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hot around the door edges
it have pipes there that the gas are running thru if it doesnt get hot there then you can be conserned
May 31, 2009 | Whirlpool ED5VHGXM Side by Side...
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Bottom face of dryer excessively hot
That is where the fan is located, hot air is drawn from the hearer at the rear of the drum, through the drum then through the fluf filter at the front (inside the front edge) and then down the front panel and to the fan, then via a duct to the rear. So would get warm at this part.
Would check that the external ducting is clear and not kinked, flexible plastic or foil ducts should not be used for these machines ie fixed ducting only.
Mark
Jun 01, 2008 | Maytag PYE2300AY Electric Dryer
Jenn-Air JCD2389G Side by Side Refrigerator Logo
233 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
