Question about Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger
My fs 45 whipper snipper is starting but running
My sthil fs 45 whipper snipper is starting but running on low power could it be the fuel? and if so should I be replacing it with a 50:1 or 25:1 2 stroke mix
  • 4 Answers
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
  • 284 Answers
Stihl recommends 50:1 with 89 octane fuel and their oil (semi synthetic 50:1 is what we use)
be sure to use stabilizer also to help with ethanol fuel issues
check your exhaust screen for clean also
stihls plug gap is .020
i wouldnt use 25:1
Posted on Jun 28, 2009
I am looking for a fuel tank for a FS81 trimmer.Mine leaks where the fuel cap fits. Looks like the thread has worn
probably missing the correct cap gasket
tanks can be found on e-bay or from a service dealers spares
Sep 30, 2016 | whipper snipper stihl fs 38
What is the gap on the coil on a sthil fs38
back firing most likely caused by the flywheel key being partially sheared. air gap for coil should be around .010
Jul 19, 2016 | whipper snipper stihl fs 38
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
My still fs36 whipper snipper runs but wont rev out
The strimmer has a small engine and therefore very small fuel passages that are very easily blocked unless a near-surgical cleanliness is observed when fueling and the air cleaner maintenance is up to date and carefully carried out.
In my experience such fuel-related problems are most likely. It is worth checking the spark plug first considering how much easier that would be. In the case of a blackened condition begin by checking the air cleaner for fouling and the cold start for correct operation.
Jul 17, 2015 | whipper snipper Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Sthil fs 38 grass trimmer will not start
does it have spark, compression and fuel.? more info please
Jul 08, 2014 | whipper snipper stihl fs 38
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Stihl whipper snipper wont start.. everything checks out ok furl spark plug etc
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
Oct 12, 2010 | Garden
Looking for a manual.
You can download the manual from;
http://www.stihlusa.com/stihl_ownersmanuals/FS_45_46_Manual.pdf
and yes since it's second hand replace the spark plug.
Apr 23, 2009 | Garden
Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger Logo
2,309 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
