Question about Saeco Spidem Villa
My Saeco Spidem Villa has just stopped working. i have had it 6 months and it has been fine until about 2 weeks ago when it wouldn't always switch on when i pressed the power button. now it has packed up completely. have have checked the fuse inside on the F1 cable and have reset the 2 reset buttons undernerth the boiler chamber. but still not working... please can someone help?
    President:
  • 1,618 Answers
Have you checked the power button to make sure it is not defective, if yes then check the capacitor under the pump to make sure it is not damaged.
Posted on Jun 30, 2009
How to stop water leak from tank
Go to saeco phillips on line and order a new seal that is mounted on the machine under a small plastic cover where the water tank conects to the machine
Sep 07, 2013 | Saeco Spidem Villa
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
My Saeco Spidem Villa leaks after it despenses the coffee. Have attempted to clean descale to no avail. Any suggestions?
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
Apr 05, 2010 | Saeco Spidem Villa
Repair spidem villa
A little spring felt off from the inside part when I was cleaning
Sep 23, 2009 | Saeco Spidem Villa
Broken"ON" button on Spidem Villa by Saeco
see repair shop. It is a ***** to replace,
Sep 19, 2009 | Saeco Spidem Villa
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
May 29, 2009 | Saeco Spidem Villa
How to descale Saeco Spidem Villa
Hi
Don't use vinegar. Its only 5% acid at full strength and if you mix it with water a lot less. It also leaves an after taste for about 2 weeks. Use descaling powder or other products especially made for espresso machines.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Mar 17, 2009 | Saeco Spidem Villa
Saeco Spidem Villa not dispencing water or steam. Need Help!
mine just wont heat up... no hot water.. have only had it for a week... what can i do?
Feb 18, 2009 | Saeco Spidem Villa
Power button loose - comes out (cracked)
Contact your reseller or your nearest Saeco Service Center as your machine will have a 2 year warranty.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 19, 2008 | Saeco Spidem Villa
Saeco Spidem Villa Logo
421 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
