Question about Refrigerators
Running almost constantly. Do not know what ideal settings should be. Freezer is 1 to 5 set at 4, fridge is CDEF - set at E ...and the carrots froze. Have not reset it - was fine a week ago. Weather is humid and has been hot but cool now. Seems to run for near an hour before it clicks off. At the bottom left inside of the fridge near the refresher there is a slide dial says cold to cool. Set in the middle and seems to be stuck there with something sticky inside it perhaps dripped into it. I don' t know what it regulates. I think it is a '94 or '96. It finally went off after about 45 minutes
  • Refrigerators Master
  • 4,655 Answers
I will need the make and model number to help you better. Thanks
Posted on Jun 28, 2009
Have a fridge freezer trf295 no model indicated. Need to get my hand on a manual. One problem is that the plug for the fridge is behind it don't know what setting fridge or freezer should be at ???
It looks like it might be a badged Sears Special.
http://www.sears.ca/content/bottom-freezer-fridges
The dials in fridges usually go from zero (defrost) to 9. Ideally you want the setting between 4 and 6. Buy yourself two fridge thermometers, they are cheap. Your freezer needs to be minus 16 - minus 18' Centigrade. Your fridge needs to be 2 - 4'C. The thermometers have a green area showing the range. Here is an example.
Aug 12, 2015 | Refrigerators
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Used armana bottom freezer fridge, not cooling?
yes leave it on for another 24 hours its probably the settings on the refridgerator
Jul 13, 2010 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Carrots and celery get soggy and limp in fridge
try turning ur fridge down to about 4 and a 1/2 maybe 3
Sep 01, 2009 | Refrigerators
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
