just got a Sub Zero 42 inch tilted it for about 10 minutes and drove for about 1 1/2 hours no very bumpy, how many hours do you have to what before turning on?
Thank you
look at the compressor and see if the lines comming out were pointing up or down wile it was tipped. if the lines were pointing up you can turn it on right away.. if pointing down i would not turn it on for at least 48 hours. if oil gets in the the little cap tube and causes a restriction it could cost you hundred$$ to fix!! did youtip again when you got it to the new spot. was it tipped more than 40*
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 685/S Stainless Steel
door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is...
(More)
door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is working.
Vacuumed coils, however, refrig continues to run. Adjusted temp, temp in within 'safe' zone, but...
(More)
Vacuumed coils, however, refrig continues to run. Adjusted temp, temp in within 'safe' zone, but continues to run. Suggestions? Thanks
