Question about Quantum SuperLoader 3 LTO-3 Tape Drive
DriveTAFlag (56) drive taflag (56) unrecovUnloadFail
How do I beat level56 cookie jam
Cookie Jam Level 56 - 3 Star Walkthrough - YouTube
? 2:31
https://www.youtube.com/watch?v=41Lzi0Ia-Ls
Jun 11, 2014 - Uploaded by Mobile Game Place
Cookie Jam Level 56 - 3 Star Walkthrough Check out http://mobilegameplace.com/cookie-jam-cheats-tips ...
Cookie Jam - How to Beat Level 56 - YouTube
? 1:07
https://www.youtube.com/watch?v=lDGiCybmBA0
Jul 9, 2014 - Uploaded by GamerU
Want to learn more Cookie Jam tips and tricks? Come check out http://gameru.com and watch all our tips ...
Cookie Jam Level 56 Tips, Tricks, Hints, Cheats and more ...
www.citygare.com > Cookie Jam
Jul 31, 2014 - Tips and Tricks to Beat Cookie Jam Level 56. 1) In Level 56 of Cookie Jam Match 3 of the same 2 Aqua Cakes, 1 Orange Ice Cream, 1 Orange ...
Walkthrough for the level 56 of Cookie Jam - Appsgare
www.appsgare.com/tips-hints-strategy-cheats-and-walkthrough-for-level...
Apr 9, 2015 - These cookie jam level 56 Tips, Hints, strategy, Cheats and Walkthrough to show you how to beat level 56 of cookie jam.
Jan 19, 2016 | Office Equipment & Supplies
How do i do - 5/8 - 2/7
Hi Molly, get the denominators to be the same by multiplying then multiply the numerators by the same - so 7x8=56 and 7x5=35 = 35/56 and 8x7=56 and 8x2=16 = 16/56 so the sum is 35/56 - 16/56 = 19/56
Oct 22, 2014 | Mathsoft StudyWorks! Mathematics Deluxe...
Vivitek 56 in hdtv dlp tv has no power after plugging in working outlet
Your color wheel drive motor is gone. So is all your money. No replacements parts are available to those who got those TV's. You got scammexd!
Apr 16, 2013 | Vivitek V37655 56" DLP TV
Without using legrange multipliers, determine the dimensions of a rectangular box,open at the top having a volume of 32ft^3 and requiring the least amount for its construction.
Given a "rectangular" box, the dimensions of side #1 will match the dimensions of side #3.
Similar for side #2 and side #4.
X = width of sides #1 and #3 of the box
Y = height of the box
Z = width of sides #2 and #4
Then, X times Y times Z is 32.
Area of side #1: X times Y
Area of side #3: X times Y
Area of side #2: Z times Y
Area of side #4: Z times Y
Area of bottom: X times Z
So, minimize: 2 * X * Y + 2 * Z * Y + X * Z
subject to: X > 0 and Y > 0 and Z > 0
and X < 33 and Y < 33 and Z < 33
Or, if you restrict X and Y and Z to be integer-valued, you can "brute-force" it,
i.e., try all combinations:
X Y Z MATERIAL_USED
1 1 32 98
1 2 16 84
1 4 8 80
1 8 4 84
1 16 2 98
1 32 1 129
2 1 16 68
2 2 8 56
2 4 4 56
2 8 2 68
2 16 1 98
4 1 8 56
4 2 4 48
4 4 2 56
4 8 1 84
8 1 4 56
8 2 2 56
8 4 1 80
16 1 2 68
16 2 1 84
32 1 1 98
So, '56' is the MINIMUM value:
2 2 8 56
8 2 2 56
2 4 4 56
4 1 8 56
8 1 4 56
4 4 2 56
Jun 04, 2011 | Acer Computers & Internet
Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
Sep 15, 2010 | 1998 Mitsubishi Eclipse
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
Thank you for posting your question here on Fixya.com.
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Inspiron 8500 laptop (80GB) intermittant boot failure
Hi
Thank you for your query
If there is a clicking noise inside then the hard drive is on the way out, the arm that reads the data is knocking against the plates, thus the noise
I would recommned that you back your data as soon as possible as the drive will eventually fail
Please can i ask that you leave feedback and vote if this has been useful
Feb 12, 2010 | Dell Hard Drive for Inspiron 8500 and 8600...
Which HP printers use #56 & 57 cartridges ?
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Jan 09, 2009 | HP DeskJet 5150 InkJet Printer
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
410 people viewed this question
Top Quantum Computers & Internet Experts
Marvin
Marvin
John Porter
Alun Cox
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
