Question about Kenmore 34723 Grab-N-Go Upright Vacuum
The Kenmore grab n go was sucking fine and then stopped sucking.
The Kenmore grab n go was **** fine and the roller turned. then I emptied it and cleaned the filter. Now there is no suction. Not just a little but no and the floor feature (no roller) won't work. What happened?
  • 75 Answers
Did you check to see if it is clogged?
Posted on Jun 29, 2009
Roller with brushes is not rotating although light is on and sucking sound is there. Is this a belt problem?Detached from floor part, the hand part is working fine. New filter. new bag.
Hi, it's Allie from Crucial Vacuum!
Your Kenmore vacuum brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. Changing the belts may be the solution to your problem.
Checking your unit's brushroll and clearing it of any tangled hair strands or debris that my be blocking the airway will be helpful. Follow by checking the internal hose for any blockages.
You can purchase direct your replacement, roller brush, filters and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kenmore.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 13, 2014 | Kenmore Vacuums
Aquamate is making a high pitch sound and the brush isn't moving
Check the belt and brush roller on your Aquamate. The belt may have slipped or be broken. There also may be a build up of hair or fibers stopping up the brush and preventing it from turning.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Apr 04, 2014 | Rainbow Rexair Brush, Aquamate R2262
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
I accidentally sucked up a thin belt that wrapped around the bristles and stopped the bristles and now the bristles wont turn
You need to remove the thin belt from the roller if you haven't already. Check the ends of the roller to make sure there is nothing there stopping the roller from turning. You can try turning the roller with your hand using minimal force.
I believe this unit has a switch on the front of the handle for the brush motor. It may cut off if the roller gets hung up. Have you tried turning this on?
In summary try cleaning everything off of the roller and then check for the switch that I mentioned. Let us know how you make out and good luck!
Mar 13, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuum has lost suction
Check the throat of the vacuum head where the air is sucked to the filter box. Check that it is not clogged.
Jan 23, 2009 | Kenmore 34722 Grab-N-Go Upright Vacuum
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Won't suck, just blows
it has a blockage - you will have to find it - probably in hose leading away from roller
Mar 18, 2007 | Kenmore 32734 Upright Vacuum
Kenmore 34723 Grab-N-Go Upright Vacuum Logo
295 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
