Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
We are renting a home that has a Frigidaire Classic Series Self-Cleaning Oven. The number on the plate inside reads: 316221001 Is this the model number? Can I find a manual online?
  • 508 Answers
Yes
Posted on Jun 28, 2009
How to use self-cleaning on 1996 frigidaire electric oven
Thank you for your post, Jewell!
From the information you have provided you would like a manual for your Frigidaire oven. I would be happy to research and see if that information is available. In order to research for any available manuals I would need your model number. You can locate the serial tag (which lists your model number) on the door frame of your oven or on the inside left hand wall. Once I have that information I would be able to better assist you. -Matt
Dec 04, 2015 | Frigidaire Ovens
Frigidaire Model CGLEF379GSA self-cleaning stove with ES340 Control: Won't self-clean after following instructions in manual.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have an older model gibson self cleaning oven. How do I start the self cleaning process. No manual. Thanks.
heatman101
Sep 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
I am trying to clean the oven,
you can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
Jan 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Oct 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I don't have a manual for this diswasher.
u can go to there site or type in the model numbers and/or the model it self and after that typ manual and it should come up on the intranet
May 01, 2009 | Frigidaire 30 in. Electric Gallery Series...
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
Lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
286 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
