Question about Acer Aspire 3610 Notebook
Random Memory access freezing.
My Acer apsire 3610 is a year old, and has recently begun sporadically freezing. THe problem appeared to be based in the memory so i replaced my 256ram with 512 ram,but the problem persists.
It can either happen when i turn the laptop on, it will get to the windows boot screen, and the laptop stops accessing memory, or at least the memory light stops flashing, and the laptop will freeze. The only way i can get my computer to switch on is to reboot many times and hope it works.
The problem can also happen when logged on to windows. I have run spybot and AVG tests, and come up with nothing.
Does anyone have any ideas??
  • 3 more comments
  • SamGray Nov 07, 2007
    There is no faultlog.txt in my windows folder. Im not sure why.
    When my laptop is running normally, the memory usage is fine, and as I get no warning before a freeze, it is difficult to get information from that! I have now flashed my bios and the problem still remains, is it possible that communication between my hard disk and my ram is faulty? Could this be causing the problem? I now know that the RAM is not at fault because i have installed new memory.
    that seemed to have worked! thanks
    Or in fact, the problem still remains..i think it might be my hard drive that is suffering.
    sorry, i thought the rating affected the status of my post, not your profile.
  • B W Dec 18, 2007
    My computer (an ACER aspire desktop) is only about 3 months old, so I know it can't be a memory problem, but while going through the startup process, it will freeze up. It is acting like too many things are trying to open at the same time. My problem started with internet issues--as in refusing to acknowledge our ISP portal (which had previously had no problems). I tried a SYSTEM RESTORE--after running VIRUS SCANS & SPYWARE CHECKS. It refused to restore--until I tried it in a SAFE MODE WITH NETWORKING. Since then, it has been okay in the safe modes, but when started normally it freezes. I have tried everything that I can think of--do you have any ideas????
  • 1,006 Answers
Possibilities read on this pics:
or :
Go to C/windows and look for a folder called Faultlog.txt. Open it and it should display all the faults that have occurred. Post a few so we can see if theres anything in particular thats causing it.
i would suggest that you reboot and get into Windows. Press [Ctrl] + [Alt] + [Delete] and click Task Manager. On the Performance tab, it will give you a reading for the amount of processor usage (which should only be a few percent when the system is sitting idle) and another counter for the amount of memory usage (this should be 192Mb, i.e. 196608Kb, or less). Minimise Task Manager.
When your PC starts freezing or looks like it's about to (if you can tell when it's going to happen), then try and bring up the Task Manager window again from the taskbar at the bottom of the screen. Has the processor usage shot up? What has happened to the memory usage? You might need to resize your screens so that you have the Task Manager running at the side whilst you continue working - that way, you'll be able to keep an eye on what's going on.
Give us some feedback about your results and we'll try and diagnose it further :)
and please if my solution was helpfull rate it as SOLVED
Posted on Nov 07, 2007
  • arben pllana
    arben pllana Nov 07, 2007
    Gp start run type MSCONFIG AND DESABLE ALL BUT NOT ANTIVIRUS AND ANTISPYBOT.If still same problem just buy new HDD 100% sure i am!
  • arben pllana
    I told you that u have a problem with hdd just buy new sir and do not rated this as thnx for trying couse i solved ur problem i told u everything you need to do and if it wont help so just bye new hdd.OK
Acer b1-710 tablet rooted slow streaming what can i configure to increase loading?
You have to increase RAM (random access memory) if it is even possible. A new part has to be installed internally to increase RAM.
Mar 26, 2015 | Acer Iconia B1-710
Install e technology on my apsire 5315
You need to download and re-install the e-machines launch manager application, You can fine the link at the following page
Mar 08, 2012 | Acer Aspire 5315 Notebook
Our machine is about 4 years old now and has recently begun tripping the GFI sporadically. In most cases it does this when the steam pump is on, either for steam or heating for hot water. Sometimes, it...
Your seals in the steam boiler are gone and it is leaking water to the switch below. The steam boiler is located just above the switch on the lower left side. You just have to replace the seals (O-rings)
Dec 31, 2010 | Saeco Magic Comfort Plus Espresso Machine
I need extra memory for acer aspire 3610 and i want to know how many GB i can put
According to page 6 of the manual, your 3610 came with system memory 256/512 MB of DDR2 400 memory, and is upgradeable to 2 GB using two soDIMM modules.
You can see a list of sources for your memory here. Additionally, you could go to Crucial's site and perform a scan of your computer for suggestions of memory upgrades.
I hope this helped & good luck!
Nov 01, 2010 | Acer Aspire 3610 Notebook
On power-up, desktop appeared, but no response to
may be it's freezing due to overheating. check that in ur bios
however if it's a software issue, then ur windows have crashed.
Perform recovery,
Feb 05, 2010 | Acer Aspire 3610 Notebook
Acer al2423W lcd monitor has begun vert-flickering
that happens when the monitor is on the way out i think you looking at new one
Nov 26, 2017 | Acer AL2423W LCD Monitor
Keyboard Malfunction
Here is a link on how to replace the keyboard on a 3600, it should be similar to your freind's laptop:
Purchase here:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 31, 2008 | Acer Aspire 3000 Notebook
Acer 3610 PC Notebook problem
yes you have to send it to acer service centre it will be cost how much i dont
Sep 26, 2008 | Acer Aspire 3610 Notebook
Acer 3610
Jan 23, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
