Question about Carrier 38CKC036 Air Conditioner
I have a Carrier 38ckc036350 Air conditioner. The inside blower turns on but the outside unit only makes a buzzing noise. I belive it is the capacitor, but I don't know where it is located any ideas?
    Sergeant:
  • 340 Answers
Have you checked your circuit breaker? Capacitors are located in side the unit in the control box. TURN OFF THE POWER. you need a capacitor checker i assume you have one if not have a qualified service person check it out you'll be money ahead in most cases. good luck Tom
Posted on Jun 28, 2009
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
The fan will not turn on in the unit itself. You can hear power get to the unit. I turned off the breaker and the noise stopped waited a couple minutes and turned it back on and the noise was inside the...
Either the relay is bad on the board or the motor has gone bad...what you are hearing is the transformer in there but it has nothing to do with the motor other then run the relays that turn on the motor...so... it could be a number of different things...relay, motor, or t-stat...you will have to have someone or you use an electrical meter and trace down the problem.
heatman101
Jun 28, 2011 | Heating & Cooling
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Carrier 38CKC036 Air Conditioner
My carrier 38ckc036350 is 6 years old. Today the compressor stopped working. The fan outside comes on and every few min i hear an electrical buzz like the compressor is trying to be energized. Are there...
Hi!
It sounds like the capacitor and/or compressor are quitting. Try getting a Start Capacitor of the same uF (I think 35 uF for Commpressor and 5 uF for fan motor) as the one you have, OR get a Start Kit from any AC parts shop for about $10 and hook it up in line with the old capacitor, if you have a two terminal capacitor plug the terminals one, on each end, if you have a 3 terminal called DUAL Capacitor, each terminal is stamped with the words FAN, HERM and the letter C for common, one lead goes in the C terminal and the other one goes on the HERM.
Install it and turn unit ON. Good Luck!! Don't forget to rate this post!!
Aug 20, 2010 | Carrier 38CKC036 Air Conditioner
Whistle noise from the air handler
Check the filter and change if dirty or restricted. Make sure the blower access panel is secured. Make sure the cooling coil is clean on the top (outside) and on the bottom (inside).
May 26, 2010 | Carrier 38CKC036 Air Conditioner
Carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Jul 20, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
842 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
