Question about LG 50PC3D 50 in. Plasma Television
Horizontal lines covering the whole screen - LG 50PC3D 50 in. Plasma Television
  • 197 Answers
Souds like bad control pcb, this model has 2 yr warranty
Posted on Jul 01, 2009
I have intermittent horizontal lines covering the whole screen. Sometimes it flickers and sometimes the lines are ghost images. When the lines are black they tend to be thickest at the right and almost...
That's a problem. If it's still in warranty you're in luck. Either take it back to the store, or call Sony to have it repaired under warranty. If it's out of warranty they can send a third party servicer to your home to the tune of $400 labor (in 2008) plus parts in the US. I will say this much, if it turns out to be an LCD panel issue, the panel will cost about the same as the TV itself when it was new.
The issue you describe sounds like the scan frequency isn't right for the video you are watching. In other words, it should be 720P and it is running at 1080P instead, and you wind up with a horizontal fold-over type of line.
That makes that new OLED TV a little more enticing!
May 21, 2016 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
Small horizontal and vertical lines cover whole screen can see pictue barely trough the lines
It sounds that the Digital Processor board has the fault. By the way, what is the brand name and model number to your TV? Check this link and see whether it can help you.
Dec 24, 2012 | Televison & Video
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Fly back lines
the unit is stating an impending breakdown in the horizontal circuit.bring it to a tech to for further analysis.
May 20, 2009 | Hitachi 27FX49B 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Horizontal green lines the whole length and width of the screen
Hey, I had the same problem with blue and red lines and this post helped me bigtime ! Just adjust the color your having problems with. Best Solutionposted on Sep 12, 2006By maddogmic Rank: Not rated Rating: 100%, 1 votes I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the
Aug 27, 2006 | Sony KP-57WS500 57" Rear Projection...
LG 50PC3D 50 in. Plasma Television Logo
190 people viewed this question
Computer Repairing
Computer Repairing
