Question about Daewoo DVRS05 DVD Recorder/VCR
My dvd player keep saying bad disc. What do I do?
  • 80 Answers
This occurs because of the disc is badly scratched,,so try to clean the disc by a soft colth, even after this the disc shows bad, the disc cannot be used with player,, thank you plz rate me...
Posted on Jun 28, 2009
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
tcobiz
  • 35 Answers
SOURCE: my polaroid dvd player keeps reporting
Is the movie a copy or an original, some copies do not work in all machines, some will accept a dvd-R but will not work with a dvd+R except if you have a brand new unit, they usually accept most discs, the older dvd players are not compatable with all blank dvd's...Steve
Posted on Jun 13, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: my rca drc277 dvd player keeps saying "no disc" when disc is in.
clean laser or replace it
Posted on Aug 27, 2009
SOURCE: dvd says 'bad disc' - how can I fix this?
I solved this on my CH-DVD 300. The laser slides in and out on two rails. It's supposed to be in the far inside position to load/read a DVD. If it's too far out of position it does not automatically return to the far inside position on startup or eject/load. I manually pushed the laser assembly to the far inside position and now my player is working perfectly again.
The laser was evidently jarred out of position by a mechanical shock, or perhaps the power failed while playing a DVD and left it out of position.
Posted on Sep 17, 2009
Dvd player keeps reading BAD DISC
either a dirty optical pickup (reads the discs) or a bad one.
Apr 27, 2012 | Televison & Video
I put a disc into the machine and it keeps saying no disc
Check the disc,see if it dirty or cracks?Tries it,with other DVD disc,same result.Ur DVD player have a bad Laser eye data's readers.Not,worth fixing as u know totay DVD players are really cheap,these days.U can get a brand new DVD player for like $40.
Nov 03, 2010 | KLH DVD8350 DVD Player
Cello tv/dvd model dcs1420 cannot tune it in
please change your optical lens this a most common problem of all dvd player. bad optical lens always no disc on screen when loading disc, even cd's are new.
Aug 20, 2009 | Emerson EWF2004 20" TV
Player justs keeps saying "bad disc" !!
clean your dvd lens with dvd disc cleaner.
May 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Teac dvd player
U LASER NEEDS REPLACEMENT
Dec 07, 2008 | Audio Players & Recorders
Portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Nov 27, 2008 | Televison & Video
Try to play a disc and the player says ''bad disc''
Have you tried unplugging the DVD player and letting it sit for a couple of minutes? If that doesn't work try holding the power button as you unplug/plug the machine.
Nov 16, 2008 | RCA DRC8052N DVD Recorder
Sd370e dvd player
the dvd player does not actually play hd dvds just upscales normal ones
Nov 29, 2007 | Toshiba SD370E DVD Player
Daewoo DVRS05 DVD Recorder/VCR Logo
2,090 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
