Question about Eureka 4337BTH Vacuum
Eureka 4337 BH vaccuum - when I connect attachments there is no
When I connect the attachment tools there is no suction through them. the vaccuum is fine when using the main carpet tool, but I would like to switch to using attachments for other hard-to reach places like the sofa or corners. I've made sure the hose is clean and has no clogs and the belt is fine.
reddevil6
  • 1673 Answers
SOURCE: Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Posted on Jan 22, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: eureka upright vac. no suction
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
SOURCE: Eureka Atlantis 2591A Extractor - Won't spray
no sray water
Posted on Jul 23, 2008
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Posted on Nov 17, 2008
Hi I have a Eureka upright bagless vacuum and I need to use the hose attachment to vaccum a car seat and floor. How do I get the suction to apply to the hose only?
Look at the top of the plastic housing that covers the brush roller. You will find an adjustment lever that switches from floor to hose. The lever may be difficult to move. It is not a feature of Eurekas that ages well.
Feb 01, 2017 | Eureka Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
No Suction
Your Power head is blocked with hair or dirt,,or the hose which connects the Upright with the power head is blocked.
Try taking a steel coat hanger apart (straighten it out) and then push it into the pickup hose to remove blockage.
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Bravo II poor suction at hose
check if the hose is clogged or the fan is broken
Jan 04, 2009 | Eureka 7606 Bagged Upright Vacuum
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Eureka 4337BTH Vacuum Logo
105 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
