Question about Mitsubishi WS-55511 55" Rear Projection Television
The R, G and B guns on my rear proj tv have gone out of alignment and I am unable to re-align them. I suspect a major control board has gone south forever. Is it worth fixing?
    President:
  • 788 Answers
Your symptoms sounds like it may have damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 28, 2009
Tv works but picture color is off and its kinda dark looking there is no duel image so i know the color tubes are ok but there is a problem it almost looks like someone took a magnet to it
You have two problems, you have a convergence problem, the convergence board needs repair, and the other problem is the coolant needs change in the guns, (CRT's) and you are looking at 500 on repairs, you would be better off getting a new LCD.
Mar 02, 2011 | Philips 43P8341 43" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
The guns are out of alignment so its showing in shadows, so how do i get them back align?
The first step would be to use the original remote to fix the convergence problem. You need to go to menu > convergence and then try to align the convergence.If you are unable to fix the convergence by remote, you need to open the TV and replace convergence IC's. This is a simple fix.
If you have an electronics repair experience and would like to repair the TV yourself, revert and i would guide you how to replace the convergence chip on this set.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 12, 2010 | Panasonic PT-47WX49 47" Rear Projection...
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have a PT-53WX53 CRT rear projection widescreen tv. The guns off and the red and blue are no longer aligned. I tried to adjust with the 9 point convergence correction but it only helped a bit. I know...
Convergence + - don't alignment or some mis alignment anywhere in the picture.The R,G,B colors lines don't move any of the color line.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergencce board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Televison & Video
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Convergence
1) Repair convergence circuit = replace STK IC's
2) Reset alignment with customer controls
3) Internal alignment,if needed.................................T.
PS. Major hand re-solder will be needed when chassis is out.
Preventative,necessary...............
Nov 28, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Rear projection problem. samsung sp48t5hp
The board sits up high above the larger boards....one screw &
four plugs sounds right. Bad part is STK392-040. If you decide
to repair----replace both IC's for reliability. I use Panasonic brand
to eliminate re-calls. Re-set alignment....done....T.
Oct 30, 2007 | Televison & Video
Mitsubishi WS-55511 55" Rear Projection Television Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
